View unanswered posts | View active topics It is currently Mon May 04, 2026 1:44 am
Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
TIE ROD ENDS
I was in the wreckers the other day and saw a couple of tie rod ends.......... CAUTION, i have no idea if these actually fit but they look similar in size to Bellett. Info given as is... ! Might be worth checking further if one has a spare steering arm ( I don't) to try the fit, and if ok, measure up length, thread size etc.
Sat Aug 09, 2014 3:46 am
Kia...... forgot to check actual model.
Sat Aug 09, 2014 3:48 am
Guys,
Did anyone get to check these out ?
Or does anyone know of any other tie rod ends out there that we can use on a Bellett ?
Mon Feb 16, 2015 4:54 am
Hi all
I am still on the hunt for Tie rod ends
Has anyone ever tried Datsun 200B or Toyota Corona ?
Tue Nov 03, 2015 9:08 am
Anyone?
Wed Nov 04, 2015 8:46 am
Not me
I need some but haven't bothered to look into anything yet........
I'm a lazy lazy man :roll:
Wed Nov 04, 2015 8:49 am
Asroc66 wrote:
Anyone?
The critical part is the taper. The thread section can be overcome with an adapter if needed.
Wed Nov 04, 2015 9:33 am
Negative for the Corona, taper too big
Next..... Datsun 200B / 240K
Thu Nov 05, 2015 5:40 am
this is the ones ...in japan ...on yahoo
Thu Nov 05, 2015 8:13 am
Yep
They Could be the ones....
I'm trying to find a longer solution for all by finding cheap readily available alternative.....
Much like the brake upgrade....
Thinking long term so we can keep enjoying our little cars
Thu Nov 05, 2015 8:49 am
this way up easier to compare
Thu Nov 05, 2015 9:20 am
sorry cant turn the pic ,,,
Thu Nov 05, 2015 9:21 am
Brake upgrade is already done.
Why reinvent the wheel?
Thu Nov 05, 2015 8:49 pm
Finally found the add in Japan
$388 + Postage is the starting bit.......
So my point wasn't specifically relating to the brake upgrade as such rather to find a cheap, readily available alternative to the NOS Bellett tie rod ends for standard vehicles....
Thu Nov 05, 2015 9:01 pm
The part number 44350-370 is the genuine number for sedans and GT's up to '66.5.
After that date it is 44350-418. According to Isuzu there is NO interchange.
They changed the steering arm at the same time. If I had a used arm and end off of a
vehicle I would use both to be safe. But. Before I do. I would check the history of the donor
and also check dimensions.
Isuzu did quite a lot of changes in the front end around certain chassis numbers and dates. '66/'67.
I haven't got any parts for the steering and suspension for vehicles prior to "66.5 so I'm not able to
compare. Maybe somebody with access to these parts might be able to check.
Fri Nov 06, 2015 12:36 pm
Alright boys and girls
Hard work is done
Place your orders
Mike Quinn Precision Engineering
Unit 32/788-798 Marion Rd
Marion
SA 5043
08 8298 7066
Thu Nov 19, 2015 6:39 am
:P
Who's the man?? You the man!!
Thu Nov 19, 2015 7:40 am
Well done. You are worth your weight in gold.
Is a bulk order going in, or every one for themselves?
Thu Nov 19, 2015 7:43 pm
Mike is a top bloke
He does ask that someone fit and test drive to be 100% sure no hang-ups
We are pretty damn sure all will be good though for early models as I supplied 66-67 rod ends as in picture as well as steering arms off the spindles
Bulk order would be welcomed though
That's up to you guys from here
Thu Nov 19, 2015 8:28 pm
THANK
YOU
:D
Thu Nov 19, 2015 8:34 pm
cron
