I was in the wreckers the other day and saw a couple of tie rod ends.......... CAUTION, i have no idea if these actually fit but they look similar in size to Bellett. Info given as is... ! Might be worth checking further if one has a spare steering arm ( I don't) to try the fit, and if ok, measure up length, thread size etc.
| Sat Aug 09, 2014 3:46 am |
Kia...... forgot to check actual model.
| Sat Aug 09, 2014 3:48 am |
67GT
Guys, Did anyone get to check these out ? Or does anyone know of any other tie rod ends out there that we can use on a Bellett ?
| Mon Feb 16, 2015 4:54 am |
Asroc66
Hi all I am still on the hunt for Tie rod ends Has anyone ever tried Datsun 200B or Toyota Corona ? Cheers J
| Tue Nov 03, 2015 9:08 am |
Asroc66
Anyone?
| Wed Nov 04, 2015 8:46 am |
Not me I need some but haven't bothered to look into anything yet........ I'm a lazy lazy man
| Wed Nov 04, 2015 8:49 am |
The critical part is the taper. The thread section can be overcome with an adapter if needed.
| Wed Nov 04, 2015 9:33 am |
Asroc66
Negative for the Corona, taper too big Next..... Datsun 200B / 240K J
| Thu Nov 05, 2015 5:40 am |
this is the ones ...in japan ...on yahoo
| Thu Nov 05, 2015 8:13 am |
Asroc66
Yep They Could be the ones.... I'm trying to find a longer solution for all by finding cheap readily available alternative..... Much like the brake upgrade.... Thinking long term so we can keep enjoying our little cars J
| Thu Nov 05, 2015 8:49 am |
this way up easier to compare
| Thu Nov 05, 2015 9:20 am |
sorry cant turn the pic ,,,
| Thu Nov 05, 2015 9:21 am |
Brake upgrade is already done. Why reinvent the wheel?
| Thu Nov 05, 2015 8:49 pm |
Asroc66
Finally found the add in Japan $388 + Postage is the starting bit.......
So my point wasn't specifically relating to the brake upgrade as such rather to find a cheap, readily available alternative to the NOS Bellett tie rod ends for standard vehicles....
| Thu Nov 05, 2015 9:01 pm |
CQGT
The part number 44350-370 is the genuine number for sedans and GT's up to '66.5. After that date it is 44350-418. According to Isuzu there is NO interchange. They changed the steering arm at the same time. If I had a used arm and end off of a vehicle I would use both to be safe. But. Before I do. I would check the history of the donor and also check dimensions. Isuzu did quite a lot of changes in the front end around certain chassis numbers and dates. '66/'67. I haven't got any parts for the steering and suspension for vehicles prior to "66.5 so I'm not able to compare. Maybe somebody with access to these parts might be able to check.
| Fri Nov 06, 2015 12:36 pm |
Asroc66
Alright boys and girls Hard work is done Place your orders
Mike Quinn Precision Engineering Unit 32/788-798 Marion Rd Marion SA 5043
08 8298 7066
Cheers J
| Thu Nov 19, 2015 6:39 am |
Who's the man?? You the man!!
| Thu Nov 19, 2015 7:40 am |
67GT
Well done. You are worth your weight in gold. Is a bulk order going in, or every one for themselves?
| Thu Nov 19, 2015 7:43 pm |
Asroc66
Mike is a top bloke He does ask that someone fit and test drive to be 100% sure no hang-ups We are pretty damn sure all will be good though for early models as I supplied 66-67 rod ends as in picture as well as steering arms off the spindles Bulk order would be welcomed though That's up to you guys from here J
| Thu Nov 19, 2015 8:28 pm |
Gunna
THANK YOU .
| Thu Nov 19, 2015 8:34 pm |
