View unanswered posts | View active topics It is currently Fri Jan 30, 2026 12:07 am
Reply to topic  [ 5 posts ]
SoCal Bellett parts(new pics)
Car(s): 1965 suzuki bellett 2 door
Here are some new pictures.
Fri Jul 09, 2010 3:33 am
steering column cover $30 kick plates $50 plastic gas pedal $10 ash tray (2 pieces) $20 turn signal assembly $20 grill $60 valve cover $25 oil cap $15 gas filler tube $15 fuel filter assembly $15 glove box $20 headlight switch $20 wiper switch $20 cigarette lighter $5 door locks no key with rubber gasket $20 ignition panel with ignition and wiper pump $30 panel below dash with two swiches $10 fuse box cover $20 door handles $5 each door handle round plastic trim $5 each dome light $25 hood release cable $15 rear window latches $40 plastic hoses from wiper pump to metal squirters in cowl $10 trunk lock no key $10 gas/temp gauge $30 high beam switch $15 stock shifter with shift knob (shift knob is cracked & missing emblem) $10 stock steering wheel adapter $15 I don't know what the the parts are worth since I don't have a Bellett. I do own a couple Datsun 510's a 72 and a 68 and I know that parts are becoming harder to find and not cheap anymore and this is the first Bellett I have ever seen so I know the parts have to harder to come by. Don't be shy make me an offer I want these parts to go to a good home. Thank you
Tue Jul 13, 2010 10:32 pm
Hate to put a damper on your keen parts collection Jeff but we over here in AUS still have quite a few Bellett's about the place and complete cars are still be obtained for $250.
But in the US it could be a very different story so i do hope someone can use the parts you have got.
Postage from US has increased enough of late to make it unviable to send most parts.
Toffa
Tue Jul 13, 2010 11:41 pm
Car(s): 74 Alfa GTV, 65 Alfa Duetto, 67 Mercedes 250 S, 67 Mercedes 250 SL, Boring Prius, Boring VW Jetta
Toffa
Depends on what is being shipped. Anything heavy but small can go in a Priority Flat Rate Box - 12 x 12 x 5, up to 20 pounds, for $56. But your point is taken. I guess Jeff and I need to hope that the 6 North American Bellett owners want some of our parts!!!! I'm still hoping for one person to buy them all, but if you have stacks of parts cars in Australia then it doesn't make any sense to ship the parts... (still hoping to get rid of my dual carb and intake setup...)
Scott
Wed Jul 14, 2010 8:50 pm
Hi Jeff,
My package arrived just before our nationals meet week before last (Sorry for slow reply).
I just want to publicly thank you for sending my Fuel Cap, Bonnet Badge and Speedo. All well packed & travelled well. I have lubed up the cap & found a locksmith with key blanks & he is making me a key. I will have the badge rechromed. The speedo has been lubed also & fitted to 'Betty" in time for the Nationals.
Km/h markings! Rare item! And working fine.
Money well spent, I reckon.
Thanks again,
Thu Nov 04, 2010 9:57 am
