View unanswered posts | View active topics It is currently Mon May 04, 2026 12:15 am
Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
parts and contracted services
I was thinking during the resto i have boxes and packets of bits purchased during the resto i was intending on keeping a log of these bits and where they were obtained.If you guys are interested i can list it here and it will help others as well if this list has other peoples input will make it easy for other people to maintain or restore. Most of my input will be gt and later wasp.
If people are interested is this section where you want it? Mabe some format to list it?
Sat Mar 27, 2010 2:22 am
great idea there gt orphan.
from a mods point of view, my suggestion is to post it in this section (parts), under a new thread title explaining what the thread is about (like the filter thread is), and i'll 'sticky' it so it stays at the top of the parts page for easier reference and location by all.
i'm in the similar position as yourself with bellett and wasp parts (although the memory will get a work out with the wasp, as it was 16 years ago!), from the resto's of all 3 of my cars, so a listing complied together, with input from other users as well, will be very useful indeed.
brett.
Sun Mar 28, 2010 1:56 am
PR 91
SWAY BAR BUSHES INNER SUPER PRO
SPF1450-21K BURSONS
LINK PIN RUBBERS
22032 REPCO NOTE FIT WITHOUT SPRING WASHER UNTIL ITS COMPRESSED OR TRIM RUBBER.
TIE ROD RUBBERS
TE2 REPCO
BALL JOINT RUBBERS
TE10 REPCO TIGHT FIT BALL JOINT END USE ZIP TIE NOT SPRING
WHEEL BEARINGS FRONT PER SIDE
TIMKEN SET LM11949/LM11910
TIMKEN SET 1988/1922
SEAL CHICARGO RAWHIDE CR17910
SPIGOTT G161
6203
THROW OUT
NSK 24TK 308E1
EXTENSION HOUSING SEAL G/BOX
400481N BURSONS
SHOCKIES F/R
MONROE 15-0176 NOTE SHOCKY MOUNTS NEED TO MODIFIED ELONGATED
Sun Mar 28, 2010 11:11 am
pedal rubbers brake/clutch
phills rotories ph 07 3205 4433
bonnet supports [threaded screw rubber top]
phills rotories
engine mounts kb20
phills rotories note these need to be modified there is enough plate on the rear to duplicate original mounts 4inch grinder cutting disc cool with water between cuts dont get them too hot,bolt through one hole vice grip other side cut and drill 2nd hole.They may sit a little higher i am not sure what height they sat original.
I have a sample back window rubber at phills and have some being made.His company is happy to reproduce any parts we require but we need to order a reasonable quantity.Otherwise in the past we have paid to have the tooling made.
As an example i am thinking of getting the number plate lenses made as every car needs 2 and out of my wrecks i dont have any to rave about.
I have no loyalities to this company its a interesting shop with nick naks that some are suitable for belletts and he is prepared to source parts.
rubber grommets floor pan boot ect
clark rubber
bellett parts dick from holland on forum
door handles,strip sedan tail lights,square tail lights,gt mirrors,ect
2 week delivery takes paypal easy transaction.
front w/screen rubbers
fastair spares ask for mark
Mon Mar 29, 2010 9:07 am
Outer
Koyo 1988/1922/Q
Koyo Hi-Cap 1988R/22
http://www.simplybearings.co.uk
http://simplybearings.co.uk/shop/p40163 ... 64d48efa12
(SKF brand too, intermittent availability between SKF and Koyo)
Inner
BCA A2
O'Reilly (USA chain store)
Bearing in Federal Mogul box is marked "NSK LM11949".
Common Federal Mogul trailer bearing.
Seal
CarQuest (USA chain store) 4249
Not an exact duplicate of the original, can be substituted if outer ring is trimmed down to clear the brake dust shield.
viewtopic.php?f=35&t=274&p=1506&hilit=bearings#p1506
Mon Mar 29, 2010 6:38 pm
thanks jt191 the more info the better
rear wheel bearings
nsk
6306c3
nsk
6206c3
seals
tc12567
tc12577
shrink ring
id 30
od 42
length is 30 mm standard the ones i got are 18mm where the seal sits its the same just ends at the recess.[to be confirmed]
These are professionals that have helped [note i have used others but i will only list ones that i would reuse]
bhss 38 smith st capalaba 07 36206555
very fast turn around 3 days
reconditioned
pr91
calipers
rear w/cyls
brake hoses
master cyls
shoes ect
wasp
all of the above
re bushed idler arm
custom chrome gold coast unit 4/20 brendan drv nerang 07 55965553
nice work,resonable price,fast turn around.
dash board restorations
you need donor dash for late model a forum member has one.
i have just cut a early dash about to be delivered this is not a necessity requirment however the dash pad i am sending has 2 small bits missing if anyone wants to make use of it while it is available.
caboolture powdercoaters 07 54280955
fast turnaround within a week nice work cheaper than sandblasting and pressure pack paint?
also does crinkle finnish door tops ect.
Tue Mar 30, 2010 10:48 am
great idea putting numbers on web relating to parts that are hard to find or use keep the good work up veryusefull , cheers rod
Wed Mar 31, 2010 8:27 am
I just found this thread and it is totally awesome.
This is exactly what this site should be about! Making sure there's a reference of available parts to keep these machines on the road!
Many thanks to GT Orphanage and JT191 for throwing up some info!
Tue Apr 06, 2010 11:50 am
water pumps
waterpumpwharehouse
isuzu forklift L4 G150
ebay usa
IF SOMEONE KNOWS HOW HOW TO ADD THE LINK GO FOR IT,AS I DONT KNOW HOW:oops:
ALSO ON EBAY IF YOU OPEN INTERNATIONAL UNDER BELLETT,BRAKE FLEX HOSES ARE AVAILABLE.
Wed Apr 07, 2010 8:19 am
Price is not bad. 10 available.
http://cgi.ebay.com/ebaymotors/Isuzu-Fo ... ccessories
Wed Apr 07, 2010 9:48 am
gt carby kits
mlp carburettors
ebay 66/67 datsun
make sure you order the one with 4 holes on the fuel bowl
ph 03 94622288
Wed Apr 14, 2010 11:44 am
Brisbane Stainless Sleaving (@ Brendale)
(07) 3889 6669
Glen Hunt is the man to talk to. Incredibly nice guy, wealth of info.
The best in the buisness & the cheapest. (usually that would be a contradiction)
Master cylinders, slave cylinders, clutch cylinders - can sleave them all
Fri Apr 16, 2010 10:43 am
bloody goood to have part no etc ,have got front end out of car putting new rubbers etc the info on parts is excellent ,keep it up cheers rod
Wed Jun 23, 2010 9:53 pm
gt orphanage wrote:
PR 91
TIE ROD RUBBERS
TE2 REPCO
BALL JOINT RUBBERS
Is there a cross reference for these (what other vehicles these boots fit)?
Or a Repco dealer that sells internationally?
Fri Jun 25, 2010 4:28 pm
Re the TE2 and TE10 baall joint and tie rod end rubbers from Repco, I have fited these to my GT that is resto rebuild and have been there for approx 6 months, car still in the air hasn't touched the ground, and all are perished and split and need to be replaced again, does anybody have an alternate brand as I don't want to replace every 6 months. :cry: :x
Fri Jun 25, 2010 9:44 pm
Roadsafe do a range of tie rod end and ball joint boots, not sure on the quality but its another option. if you tell me the sizes of the top and bottom holes i can give you part numbers.
Fri Jun 25, 2010 10:26 pm
OK, I had expected these were tried and tested and found to fit and last.
It looks like I should measure and track down something with Mr. Flibbles.
The bellows look comically over sized and unlike anything modern. The urethane universal fit are so small they couldn't fit well if they did seal.
No chance new ball joints could be found I suppose...
Sat Jun 26, 2010 3:09 am
i have a rack at work and was trying to find the correct looking style boots for them, and some for the ball joints. I might give the local repco a ring and see if they can tell me the sizes of there boots, than i can at least give you guys an alternative roadsafe part number.
havent found any listing for the ball joints yet, but there are places around that can rebuild the ball joints for you. I had some done by a guy with the name of Quinn down richmond area in SA, cost a bit but these were for an old early model Scat and we couldnt source them anywhere.
Sat Jun 26, 2010 4:28 am
i have just fitted steering rack boot , repco universal fit urpb boots , tie rod rubbers te2 repco cheers rod tassie
Sat Jun 26, 2010 7:50 am
Sorry jt191 none of the parts above i have recomended.It is only a log of parts used on our resto projects that is open for public reference and for others to add to also[as you have in the past].It would take me twenty years to be able to personaly recomend these parts as my gt that goes has only done aprox 1000kms in 12 months.I would recomend anyone wanting to use any of these products to do your own research on quality/warrenty and purchase and use at there own risk.I would recomend any modification to these parts be researched before doing so.
Sat Jun 26, 2010 10:55 pm
