[ 7 posts ] |
2ldohc
Joined: Wed Sep 10, 2008 1:22 pm Posts: 603 Location: Adelaide, Australia
A 52mm thermostat also seems to be the best size.
I'll post some pics to confirm this after I driven the car for a week or so!
Cheers, Ross
_________________1966 Prince Skyline GT-B 1968 PR20 Bellett Deluxe (flat lights) 1970 SRL311 Datsun Fairlady 1971 S30 Datsun 240Z - Race car 1972 S30 Datsun 240Z For more info, articles and pictures visit http://GarageofAwesome.com.au
| Thu Oct 09, 2008 3:05 am |
2ldohc
OK, here's the follow up for the thermostat housing. As you can see from the first photo they are not a 100% match but the bolt pattern is identical and the angle of the outlet is right. Attachment:
The next pic shows that the oulet's angle is again slightly wrong but in this case beggars really can't be choosers! Attachment:
And lastly, the finished product. I had to use two gaskets when I put this back together but this was mainly because I was worried about breaking a second one plus the block wasn't particularly flat! As you can see the outlet pipe is noticeably bending the top pipe but I don't think this will effect anything Attachment:
I'll post again once I can actually drive the car (the brakes are stuffed again!) and have had a chance to see if it leaks etc. Cheers, Ross
| Thu Oct 09, 2008 11:57 am |
antus
Site Admin
Joined: Sat Sep 06, 2008 1:17 am Posts: 208 Location: Adelaide
Looks like it'll do the job. You could probably cut about 2cm off the radiator end of the pipe and get it fitting straighter, though.
| Fri Oct 10, 2008 7:33 am |
dave
WTF has gone wrong with the brakes! they worked killer when I drove it!
| Fri Oct 10, 2008 10:57 am |
2ldohc
The back right wheel cylinder failed in a big way... Went out to move the car to do the thermostat last week and it wouldn't move... On closer inspection the back right wheel was sitting in a puddle of brake fluid (the entire reservoir to be exact!).
Pulled it all apart and cleaned it all up but might need to get the slave cylinder recon'd before I can get it on the road. I'll find out tomorrow!
| Fri Oct 10, 2008 2:06 pm |
dave
what a pain in the arse!
| Fri Oct 10, 2008 9:08 pm |
BettyBellett
Car(s): 66 PR20 sedan
Reference to thermostat housings - Not too many years back, I was able to buy the Genuine part from ADELAIDE TRUCK SPARES. Evidently the same part is used on a small Isuzu truck - model unknown. The label reads ISUZU GENUINE PART ; ISUZU Pt No. 9-13713064-1; P No. 94021888; Des PIPE;WATER Fig key No. 031-049
However, putting all that aside, I am currently running a WO33 from Killkenny Castings which is to suit an RT18 four cylinder engine from a Toyota 1977 RA28 Celica. A housing from an RT18 engine in a Corona does suit but pipe exit is at slightly different angles I believe.
| Wed Jan 07, 2009 2:07 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 0 guests |
