View unanswered posts | View active topics It is currently Mon May 04, 2026 12:01 am
Engine and Gear box Mounts!
GT Orphanage, would you like to post a picture or two??
1968 GT.
Thu Mar 04, 2010 9:41 pm
the kb mounts that gtorphanage is describing sound like the ones posted earlier, in the pics, without the 'hook and tab' on the top section.
these are the ones i used in my Wasp years ago.
pics are a good idea too.
Fri Mar 05, 2010 8:49 am
I will post some before and after mod picks.
Brett is correct the same as the photo earlier in this post one hole is out that needed to be drilled the rest was a trim with a cut off wheel in a grinder.The mouts sit 30 mm taller then the old ones however i do not know how tall it would have been new as the one i am using is not healthy.
I have internet issues at the moment when it is soughted out i will post a couple of picks.
Sun Mar 07, 2010 3:47 am
I'm waiting on the molds for the suspension bushings and thought I would work on the engine mounts.
I narrowly missed out on a set of new-old-stock Bellett engine mounts to pattern from. I suspect the 40 year old mounts will have flattened some if they did not rot in two or tear in half. I wanted a measurement of thickness and the durometer (hardness) of the rubber.
I obtained an aftermarket Chevy LUV mount to look at.
Is the Bellett engine mount the same thickness as the LUV engine mount?
Is the rubber hardness between the two the same? Has anyone using the LUV mounts noticed an increase or decrease in vibration versus the Bellett mounts (when they were in good condition if you can remember)?
For lack of anything exact, I would probably do 65 durometer for a street performance mount, and 85 durometer for a race mount.
Sat Aug 21, 2010 5:31 pm
Car(s): Isuzu Bellett 1972 PR50
Hi all. Please, show me foto of original engine mount and bushes
Sat Aug 28, 2010 2:22 am
New re conditioned engine mounts on ebay:
http://www.ebay.com.au/itm/172080416674 ... 1555.l2649
or:
A&A IGLIO ENGINEERING
8 Hill rd, Wingfield. 5013
PH: 08 82432016
They specialise in vulcanising all types of rubber mounts.
Fri Jan 29, 2016 3:58 am
http://www.ebay.com.au/itm/172080416674 ... 1555.l2648
Fri Jan 29, 2016 4:10 am
I got a set of these a couple of months ago (were slightly cheaper then I could get a one off set done locally)
Price has gone up a little since but that's to be expected as their supply gets lower
Get em while ya can I always say ;)
Fri Jan 29, 2016 11:41 pm
Users browsing this forum: Baidu [Spider] and 4 guests
