View unanswered posts | View active topics It is currently Sun May 03, 2026 7:00 pm
Reply to topic  [ 8 posts ]
twin solex linkages
Looking for help with linkage setup for twin solex 40PHH setup on 1800 twin cam.
If anyone can put any photos up of their setup.
If anyone has a linkage setup willing to sell.
If anyone can point me towards any suppliers that have a range of linkages they have used to do this setup.
Am in Adelaide.
Thu Aug 25, 2016 11:27 am
Don't use linkages. Always too much play in them and forever adjusting. There's not enough room for linkages on them anyway.
And never have one carb operate another. They will bend throttle shafts if set up that way.
Use a Weber style centre adjuster so each carb operates separately. Easy, neat, and works the best.
Thu Aug 25, 2016 9:47 pm
And if possible use a - cable - from the "Weber centre adjuster" to the accelerator pedal - overcomes 90% of linkage slop ,is lighter , lots neater and takes up a lot less room.
Thu Aug 25, 2016 10:28 pm
Forgot that bit. Cheers KB.
Gemini cable works well on them.
Thu Aug 25, 2016 10:34 pm
Can anyone put up a few photos of the webber type setup PR91 is talking about.
Fri Aug 26, 2016 12:29 am
With thanks to Google. I'm nowhere near mine ATM.
3 of mine use this. Easy to set up and doesn't ruin the carbs over time.
EBay has them. Look up "Weber throttle levers".
Fri Aug 26, 2016 1:21 am
Cheers PR91, Looks like a fun couple of weekends in the shed for me. :D
Fri Aug 26, 2016 2:42 am
And do not forget to "soft mount" the carbies - they are meant to be able to be moved (like they were left a little bit loose ) Many a carby has been ruined by people installing the soft mounts and then tightening the nuts until the carby "ears" are bent - not an easy thing to repair.
Fri Aug 26, 2016 3:26 am
Users browsing this forum: Google [Bot] and 9 guests
