View unanswered posts | View active topics It is currently Mon Mar 23, 2026 4:30 pm
Oil Pressure SENDER
Looking for an alternative or Gemini part number for an oil gauge sender that suits the Bellett.
I believe a Gemini will fit and work, however I would like the correct part number if anyone has it please?
My pressure switch at the lower RHS rear, side of the engine has developed a minor leak and I wish to replace it ASAP.
If anyone can help please before I rush out and buy an incorrect part!
I know it is on here "somewhere", I have looked and can not locate the post.
Wed Feb 10, 2016 10:03 pm
1968GT wrote:
Looking a alternative or Gemini part number for an oil switch that suits the Bellett.
see http://www.bellett.net/forums/viewtopic.php?f=36&t=3103&p=31691&hilit=oil+pressure#p31691
Wed Feb 10, 2016 11:18 pm
Well I have found out what I am after, I used the incorrect terminology, I am looking for the OIL PRESSURE GAUGE "SENDER"! (Mine in the GT has sprung an oil leak)
I have found a Yazaki sender for the Yazaki gauges, (after market) I have ordered the part and will advise after fitted how it works. It is a part used over the same model years as Isuzu in the Bellett, only in the Toyota Hi Lux for Yazaki gauges, fingers crossed it works!! ;) $67.00, the original part was $190-00, GOOD OLE TOYOTA!!! :x
Sat Feb 20, 2016 3:46 am
I now have the part and it looks good.
As I am about to be away for a while, the installation will have wait until I return.
I will let you know.
Wed Mar 02, 2016 11:21 pm
