View unanswered posts | View active topics It is currently Sat Mar 21, 2026 3:30 am
Reply to topic  [ 203 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
Screamin' Squirrel II
..After One Good Coat Of Stripper..
Ted Freeman
Sun Jan 24, 2016 3:51 am
Ted Freeman
Sun Jan 24, 2016 3:53 am
Ted Freeman
Sun Jan 24, 2016 3:55 am
Ted Freeman
Sun Jan 24, 2016 3:56 am
Ted Freeman
Sun Jan 24, 2016 3:59 am
Ted Freeman
Sun Jan 24, 2016 4:02 am
........After The Paint Stripper I Will Go Over All Of The Insides With Various Types Of Abrasives To Achieve The Bare Metal Result I Desire, Then & Only Then Will I Start Etch Priming & So Forth........
Ted Freeman
Sun Jan 24, 2016 4:07 am
.........After The Paint Stripping Most Of The Final Bare Metalin' Will Be With The Air Dremmal, I Have A Small Wire Brush Wheel Displayed Here, Others Such As What I Call (Carpet Disc's) Will Give A Far Better Result, Initially I Used The Wire Brush Wheel To Get The Inner Left Door To Bare-Metal Without Using Paint Stripper, So Methods Are Constantly Evolving.........
Ted Freeman
Sun Jan 24, 2016 4:19 am
..........The Two Front Guards Needing A Fair Bit Of Work To Get Them Both Up-To Par..........
Ted Freeman
Sun Jan 24, 2016 4:23 am
...........Tucked Away So The Next Item Can Be Started & Prepped...........
Ted Freeman
Sun Jan 24, 2016 4:29 am
............Dad Is Prepping For Fuel Tank Removal............
Ted Freeman
Sun Jan 24, 2016 4:32 am
very thorough work. Thanks for great pictures
Sun Jan 24, 2016 5:27 am
.The Various Ways Of Achieving The Desired Bare-Metal Results, I Now Opt For Paint-Stripper First Then The Rapid Strip Wheel & The Carpet Strip Discs For The Tight Spots, These Three Methods As I Have Found From Personal Experience Will Get The Results Desired & Then Some But Not Saying That This Is The Only Way, But A Way That Works For This Particular Application,
In The Picture Provided One Can See The Different Effects From The Various Products..
Ted Freeman
Mon Jan 25, 2016 12:44 am
.Inner Boot Preparation.
Ted Freeman
Mon Jan 25, 2016 5:10 am
Ted Freeman
Mon Jan 25, 2016 5:12 am
Ted Freeman
Mon Jan 25, 2016 5:14 am
Ted Freeman
Mon Jan 25, 2016 5:15 am
Ted Freeman
Mon Jan 25, 2016 5:17 am
Michael is a bit concerned he might be swamping the site with photos, let us know if you tire of our musings!
Ted Freeman
Mon Jan 25, 2016 10:16 am
keep em coming mate its good to see postings goes bit slow here at times ...cheers davo
Mon Jan 25, 2016 10:58 am
