View unanswered posts | View active topics It is currently Mon May 04, 2026 12:15 am
front shocker
Can someone confirm that front shocker for bellett sedan are Holden HR
Mon Jan 12, 2015 2:24 am
Yes
Mon Jan 12, 2015 3:21 am
Mon Jan 12, 2015 3:26 am
Bellett front and rear are the same, and match HT/TK/HG (68 - 70) FRONT. For standard height.
Just one thing, some brands have thicker housings than others. If you can, take a standard one with you to match up, otherwise you might have to grind the hole in the wisbone a little wider to get it through. KYB should go tnrough. Back in the day, there were 2 different shocks, one for 6 cyls and one for V8s. I bought the 6 ones as the V8 ones were too hard.
Mon Jan 12, 2015 11:53 am
Claws
viewtopic.php?f=35&t=464&p=2823&hilit=shock+absorbers#p2823s
plenty of info
also Ebay
http://www.ebay.com.au/itm/Holden-HK-HT ... 4631c64e3a
Regards Flying
Mon Jan 12, 2015 9:32 pm
wow that is not real cheap.
Pedders do a comfort gas shock for about $90 each.
ride quite nicely and being gas dampened, perform well too.
Mr Flliiibbbllleeessss may be able to steer you in the right direction.....
Tue Jan 13, 2015 9:47 am
