Leave it CRUSTY! Like Donkey's Attachment:
| Fri May 23, 2014 1:23 am |
pa_man
I polish my crust!!
| Fri May 23, 2014 4:50 am |
redback
We only have buffalo skull up here in the nt, not sheep skulls, and I don't think my visor will hold the weight........
| Fri May 23, 2014 8:07 am |
Anthiron
Joined: Wed Mar 05, 2014 6:21 am Posts: 57 Location: Sunshine Coast QLD
Its been a while since I was on here! Couple of new pics of the Luv   I am going to be supercharging the engine with most likely an AMR500 (just trying to find a decent one for cheap). I have a 45mm DCOE Weber to use with it. Idea is to run the SC just forward of where the stock carb sits and the side draft weber on a 90 degree home made manifold. If I run a 2:1 pulley it should see around 8psi max and this will keep the unit under its 16000rpm redline. Anyone have any tips or ideas here? It will be a big trial and error system for me currently.
| Wed Nov 19, 2014 11:16 pm |
Anthiron
| Sun Jan 18, 2015 5:22 am |
I think this is same type? On a Corolla. Might give you some ideas on mounting perhaps.
| Sun Jan 18, 2015 7:52 am |
dave
That's such a cool truck!
| Tue Jan 20, 2015 8:54 am |
Anthiron
Glenn wrote: I think this is same type? On a Corolla. Might give you some ideas on mounting perhaps.
glenn Interesting snout setup to line up the pulleys. To be honest I have put the supercharger idea on a bit of a back burner while I work on my Cortina but still keeping an eye out for an AMR500 cheap.
| Wed Jan 21, 2015 8:23 pm |
Users browsing this forum: No registered users and 15 guests |
