[ 7 posts ] |
hi I am chasing a choke cable for the 90 anyone got spares ??... I have a good black ''c'' which you pull ( this don't sound good but you get the idea ...do you ) just cable is r/s ..have cash waiting cheers davo
| Sun Aug 17, 2014 9:11 pm |
BULLITT wrote: hi I am chasing a choke cable for the 90 anyone got spares ??... I have a good black ''c'' which you pull ( this don't sound good but you get the idea ...do you ) just cable is r/s ..have cash waiting cheers davo there used to be, maybe still, universal Choke cables available from Auto stores, if all else fails, Dave
| Sun Aug 17, 2014 10:50 pm |
yellowperil
Glenn is correct, I had to replace the choke cable in the yellow peril some time ago and found one at either Repco or Bursons ( I can't remember which as I find lots of universal parts at both).
It is branded as Bonnet release/ choke cable and you cut it to the desired length. the only problem was that it comes with the cable attached to a standard black knob, not the one with the "C" in the middle. Cheap as chips, around $20 from memory., threaded in nicely and was long enough to give a nice wide loop for easy operation. Piccies attached
YP
| Fri Aug 22, 2014 11:25 am |
yellowperil wrote: Glenn is correct, I had to replace the choke cable in the yellow peril some time ago and found one at either Repco or Bursons ( I can't remember which as I find lots of universal parts at both).
YP for a more 'original' under bonnet look, buy some black heat shrink tubing from Jaycar or Altronics and shrink it over the exposed outer, once the length is worked out.glenn
| Sat Aug 23, 2014 12:47 am |
thanks guys got a brand new one from Caloundra it has the original 'c 'on it great it looks as the old one ..im stoked $20 cheers davo
| Sat Aug 23, 2014 1:17 am |
BULLITT wrote: thanks guys got a brand new one from Caloundra it has the original 'c 'on it great it looks as the old one ..im stoked $20 cheers davo good work, Dave.... keep chipping away.....
| Sat Aug 23, 2014 1:26 am |
Good result mate, cheers, Matt.
| Sat Aug 23, 2014 12:17 pm |
[ 7 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 14 guests |
