michiel
Car(s): 1972 Isuzu Florian
| Mon Jun 22, 2009 9:49 am |
bellett65
Joined: Sun Oct 12, 2008 7:14 am Posts: 157 Location: Cranbourne Victoria
I do know the bellet rears can be replaced with older BMC wheel cylinders. They have to have the nut on the pipe changed. i would suggest you find a dealer that sells BMC stuff. there should be a few around. Also you may be able to pm IZU069. I he does not know no one will he has a great knowledge base as far as Isuzu is concerned, He has Florians.
peter
_________________ Since the day of my birth, my death began its walk. It is walking towards me, without hurrying
| Mon Jun 22, 2009 9:54 am |
michiel
Cheers, that's a big step in the right direction I guess!
| Mon Jun 22, 2009 10:17 am |
OzLuvTrucker
Car(s): 1980KBD40 ISUZU
Check theese out on eBay they're used in 72-75 Chevy Luvs drum brake fronts. http://cgi.ebay.com/ebaymotors/72-75-CH ... 3a1318Q7c3
| Mon Jun 22, 2009 10:45 am |
michiel
I'm afraid the Luv brake are quite different - probably because of the difference in lugs etc?
| Mon Jun 22, 2009 11:02 am |
michiel
Mechanic drew me a picture, maybe this helps? I'm not very technical myself, so I'll leave the interpretation of this artwork to you... Diameter of the cylinder itself is 25mm.
Edited because I've deleted the pics...
| Mon Jun 22, 2009 2:58 pm |
michiel
michiel wrote: I'm afraid the Luv brake are quite different - probably because of the difference in lugs etc? I should have looked better, sorry! It's the same thing, the angle confused me... bought one, now all I have to do is wait for it to turn up. Thanks guys for the quick responses!
| Mon Jun 22, 2009 10:22 pm |
michiel
No no no, it's all wrong... comparing the pics I should have seen it. Has anyone got any ideas? I'll try to contact IZU069 again...
| Fri Jul 03, 2009 9:22 pm |
OzLuvTrucker
michiel wrote: No no no, it's all wrong... comparing the pics I should have seen it. Has anyone got any ideas? I'll try to contact IZU069 again... What is the difference? are you aware there is a left and a righthand cylinder.
| Wed Jul 08, 2009 9:51 am |
michiel
The big difference is the sort of trapezoidal piece that the originals have, the upper part on my pics. The others don't have that extra bit. I have now sourced a set of the right cylinders though!
| Wed Jul 08, 2009 10:43 am |
OzLuvTrucker
michiel wrote: The big difference is the sort of trapezoidal piece that the originals have, the upper part on my pics. The others don't have that extra bit. I have now sourced a set of the right cylinders though! Glad to hear you have sourced the correct parts, maybe you should consider a disc conversion in the future.
| Thu Jul 09, 2009 10:57 am |
michiel
Thanks - good point about the disc thing, I'm trying to collect as much info as possible for the future. I'd love to keep it standard, but discs could solve a lot of parts issues indeed...
| Thu Jul 09, 2009 2:54 pm |
JDMPalace
I have had issue with my passenger side and it seems to have a leak since I keep bleeding the system and after being park for couple of weeks all fluid is gone and brake is down. So is there any new replacement wheel cylinder that could work in Rear of Bellett GT?? There are no spare parts for this car in state so any help is appreciated.
| Tue Jun 22, 2010 7:37 am |
PR95
Hi JDMPlace wecome aboard, you should be able to get your rear wheel cylinders resleeved, we have them done with a stainless steel sleeve, should fix your problem Geoff
| Tue Jun 22, 2010 10:10 am |
