View unanswered posts | View active topics It is currently Sat Mar 21, 2026 10:38 am
Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
WTD: PR91 GT Parts
The Bellett is going in for a bodywork quote next Saturday...before I get too far with it, does anyone have a bever panel? Surely someone has a wreck?
Glenn, PM sent.
Sat Jul 12, 2014 1:49 pm
sedan would be the same........... :)
Sat Jul 12, 2014 11:47 pm
Glenn, PM sent.
you can make one at home, tedious maybe, but can be done. I did one on my GT (now Daves) I replaced about 2/3rds of it from the bottom where the main rust is, upwards.
Any decent bodywork place though should be able to do it also. Time is money though.
Heres a good one :( :(
Sun Jul 13, 2014 12:15 am
Yes, I figured as the sedan was the same there may be a wreck laying around somewhere.
I have a feeling mine may not be repairable, so might be looking at a repro panel unless I can find a secondhand replacement...very unusual rust in mine, probably likely to storage in a damp shed for years. However, undercarriage is otherwise mint, including the boot. :!: :?:
Sun Jul 13, 2014 12:21 am
most Belletts i have seen get water down in that area and of course they rust. Same with the bottom of rear quarter panels as you know.
What i always do when replacing these sections or evn those that are OK, is to open up the crappy (tiny) weep holes in the bottom and i also add more to let the water out hopefully.
I open them up with a largish screwdriver, push it in and twisting a bit also trying to keep the 'expansion' on the inside so not visible.
To add more, do the same thing, push a screwdriver in selected spots between spot welds to make additional slots. Once all repairs done, add copious amounts of fish oil and let the excess drain out of the new holes !
Sun Jul 13, 2014 12:30 am
Thanks Glenn, good tip!
That beaver panel certainly looks a hell of a lot worse than mine, but I have the feeling there may not be much of mine left after wire brush or sandblasting. I guess I'll find out next week when it goes in for a quote. :|
Sun Jul 13, 2014 12:40 am
this one is pretty bad but most seem to rust only in the lower 1/3rd or so making a replacment simpler generally
Sun Jul 13, 2014 1:23 am
a side topic but I had a cracked foglight and two brackets for them.
I promised them to Degruch, but can't find them now.
Did anybody get them from me in recent past??? Maybe I already gave them away (I can't recall) If you got them, let me know PLEASE.
Sun Jul 13, 2014 2:31 am
Duane even if you found a good panel on the outside it would not be so pretty on the inside and probably to thin to weld anyway. new would be worth the xtra $
Sun Jul 13, 2014 10:10 am
Speedo procured today, still searching for everything else...however, the body guy didn't seem too distressed by the beaver panel, so maybe I'm overreacting there.
Sun Aug 03, 2014 1:01 pm
be careful he doesn't just plan to 'bog' it though...... it would usually need to be remade up to the bumper brackets at least buts not a complex shape anyway.
Sun Aug 03, 2014 11:42 pm
Found one .....
Tue Aug 05, 2014 10:34 am
how much ...dick ....
Tue Aug 05, 2014 10:47 am
Wow! Too new for me, unfortunately...or I could buy it and weld the strip light holes up. :P
Thanks anyway Dick! :mrgreen:
Tue Aug 05, 2014 11:04 am
Got them also with 1968 lights, sorry no teardrops.
Tue Aug 05, 2014 11:35 am
How much are they, Dick?
thanks
Tue Aug 05, 2014 11:57 am
I will ask the owner, will depend on how much of these panels he has in stock. Will get back ...
Tue Aug 05, 2014 12:41 pm
Cheers Dick, mine is a '67 with the square tail lights.
Wed Aug 06, 2014 3:45 am
Dick wrote:
Found one .....
Dick, could you take a picture of the inside also please? I am curious as to how the panel is made. Especially around the bumper bolt area.
Wed Aug 06, 2014 6:39 am
hi dick what bout the rear gaurds below the line and any gt window rubbers ??? prefer with chrome strip to fit ....and also the rear swing out window rubbers ??to suit ...I gotta start somewhere ...cheers davo now a pr90 owner ..
Wed Aug 06, 2014 7:11 am
Users browsing this forum: Google [Bot] and 10 guests
