View unanswered posts | View active topics It is currently Sun May 03, 2026 11:35 pm
Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
G150 Rebuild Kits?
Yes I am absolutely going to remove welch plugs for an acid bath (it has been sitting in the back of my shed for 10 years I think - I remember doing the same for the motor in Stinky now.
It is not a rant when it is advice CQ - all good. I am very open to advice - that is why I post these things so Bellett.net can give me heads up!! I thank you all!
Thanks Dave for the info on the Cam Bearings - will let you know how I go.
Wed Nov 06, 2013 8:58 pm
gt orphanage wrote:
just make sure you can get cam bearings before you go acid bathing it :!: they are a little hard to find ;)
has anybody solved this problem of cam bearings ? I had same issue way back in 90's on the GT engine rebuild.
Wed Nov 06, 2013 9:32 pm
Somewhere in the old memory bank I recall that 1200 Suzuki Motor cycle bearings were being modified to fit. :roll: :?:
Wed Nov 06, 2013 11:22 pm
I think you will find that Suzuki mod was twin cam.
Thu Nov 07, 2013 12:39 am
does anybody have the dimensions of the bearings (Bellett that is)
Thu Nov 07, 2013 1:01 am
Hello Glenn,
I found this info on camshaft bearings this morning:
Camshaft Bearing Set 3C6127
Oversize STD
Brand ACL
Manufacturer ACL
Camshaft Bearing (c) 6127
- 1,2,3
OE Part Number 1 5-11611-002
Manufacturer ACL
Min Std Shaft Size 1.7707in / 44.975mm
Max Std Shaft Size 1.7707in / 44.975mm
Min Std Tunnel Size 1.8902in / 48.01mm
Max Std Tunnel Size 1.8909in / 48.03mm
Max Wall At Crown 0.0591in / 1.5mm
Max Overall Length 1.0000in / 25.4mm
Semi-finished N
Min Vertical Oil Clearance 0.0014in / 0.035mm
Max Vertical Oil Clearance 0.0037in / 0.095mm
Material F23
MAIN BEARINGS:
Main Bearing Set 5M2817
Oversize STD, .25, .50, .75, 1.00, 1.25, 1.50
Brand ACL Duraglide
Manufacturer ACL
Main Bearing (c) 2817
- 1,3,5
Half Type Identical Halves
OE Part Number 1 9-11510-609
OE Part Number 2 9-11510-141
Manufacturer ACL
Min Std Shaft Size 2.2016in / 55.92mm
Max Std Shaft Size 2.2022in / 55.935mm
Min Std Tunnel Size 2.3220in / 58.98mm
Max Std Tunnel Size 2.3228in / 59mm
Max Wall At Crown 0.0596in / 1.513mm
Max Overall Length 1.2650in / 32.13mm
Min Vertical Oil Clearance 0.0007in / 0.019mm
Max Vertical Oil Clearance 0.0031in / 0.08mm
Material F780
Main Bearing (c) 2818
- 2,4
Manufacturer ACL
Max Overall Length 0.8299in / 21.08mm
Material F780
Hope that helps mate.
Thu Nov 07, 2013 1:06 am
I have a new set here a forum member helped me get :!: it's up to that forum member to say if he can get more as I think the supply is low if not gone.
Thu Nov 07, 2013 1:09 am
Thanks Neil
I don't need any now, but the info could help soembody out maybe. I wonder if the SOHC and DOHC lay shaft uses the same bearings.... i would imagine so.
Thu Nov 07, 2013 4:02 am
last time I checked acl no longer had stock and were not making any :?: Maybe a group buy I would get a couple more sets.
Thu Nov 07, 2013 5:14 am
thatmight be the way to go, a group buy or maybe a Club purchase as these will always be a problem otherwise
Thu Nov 07, 2013 5:33 am
I have already checked with acl about getting them remade and they will do them but need to order a min of 300 sets very expensive I'll have a look through my spares as I should have a few spare sets that I won't need. Peter.
Thu Nov 07, 2013 7:37 am
Hi Peter,
do you know if they also fit SOHC and DOHC engines.
Thu Nov 07, 2013 7:57 am
The ones I have are nason 3c6127n made in Taiwan box says for g130/150/161/180/200 ? Maybe they might be of help :?:
Thu Nov 07, 2013 8:09 am
Hi Glen they will fit 1800 block as well
Thu Nov 07, 2013 8:31 am
thanks Peter.
(long time no see, mate)
Thu Nov 07, 2013 9:08 pm
might be worth asking at Bursons etc........ thanks
Thu Nov 07, 2013 9:12 pm
