View unanswered posts | View active topics It is currently Tue Mar 31, 2026 8:58 am
Reply to topic  [ 112 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Water pumps
Car(s): 1968 Isuzu Bellett
Stanmore Auto Services has been cleaned out!
All the water pumps went to Australia and I am told there is no longer any in New Zealand
Mon Jan 11, 2010 10:51 pm
Hey guys,
A friend of mine managed to track down another water pump. It's a NOS pump made by GMB.
The Part number for this is GWIS-13a like the ones stanmore autos had in stock. But it says it is for a G161 engine.
Can anyone confirm if the G150 and G161 share the same waterpumps?
Mon Mar 01, 2010 3:28 am
Try this site they have a PDF file with pictures of the pumps. It does look close from my memory.
http://www.kingleadtrade.com/catalogue/ ... st2007.pdf
This is from NUTEK site
http://www.nutekpart.com/productContent.asp?ID=258
FASTER 1600 72. ~76. KB-20 G-161 GWIS-13A 9-13610-319-2
    76. ~80.10 KB-20 G-161Z GWIS-01A 8-94202-477-1
Mon Mar 01, 2010 10:06 am
just handed to me (literally 2 minutes ago!) by 'toomanybelletts' is a rebuild kit for the 3 bearing engine.
brand is: ASAHI.
part no: "kit" R-200.
to suit: bellett gasoline. 1964-66. PR10 & 30, KR10, KR10V (G130). PR20 & 80 (G150).
box is green and red, with white writing.
came via yahoo auctions in japan. approx $80 plus freight.
also shown on the box is another part no, stating "pump" P-200.
while this is for the early engine, it gives a starting point (ie: brand name, part number reference, look of the box, etc) to chase details for the later 5 bearing pumps and/or rebuild kits as well.
Thu Apr 01, 2010 4:35 am
I have 2 waterpumps on the way to australia when they arrive and it is confirmed that they fit?i will pass the info on.
Thu Apr 01, 2010 1:01 pm
waterpumpwharehouse on ebay motors usa isuzu l4 forklift g150.
Wed Apr 07, 2010 8:57 am
I learnt today the differance between the water pumps backing plates.The plate on the back of the pump in the 5 bearing engine bolts complete with the plate supplied to the block.In the wasp 3 bearing the block has a plate the sits behind the timing gear that bolts to the block this plate also is used for engine mounts,generator as well as the water pump backing plate.We will remove the plate supplied with the pump and bolt it on to Walter the wasps engine plate.
Thu Apr 08, 2010 10:49 am
Digging up old posts
Sat Jul 20, 2013 1:40 am
there was a company in the us called the waterpump wharehouse thye sold waterpumps for a g150 forklift. This may be a lead or someone may have parts for the forklifts? 1 would assume that they have g150 engines :?: :?:
Sat Jul 20, 2013 1:45 am
Mark
Sat Jul 20, 2013 1:59 am
Hi . I just took hy old. Pump to Bursons . The got them re built . Gricey
Sat Jul 20, 2013 5:57 am
My daughter in law runs spare parts for a fork lift company . I will let you know what she finds out . Gricey
Sat Jul 20, 2013 6:01 am
hi guys just in case I have a g161 flo motor will the kb20 luv(76-81) fit it ?? looking in the future cheers davo
Tue Oct 01, 2013 6:57 am
Davo I don't think so it is only the early luvs.
Tue Oct 01, 2013 11:36 am
not if its the G161Z motor (same as the gemini)
you will need a waterpump that fits early Chev Luv 1972-1975
like this one!
http://www.ebay.com.au/itm/CHEVROLET-Lu ... 8d0&_uhb=1
Tue Oct 01, 2013 11:41 am
HI GUYS I AM A MUSO (SO CALLED).... SO THE 1600 G161 MOTOR (BELLETT /FLORIAN) MOTOR THE WATER PUMP WONT FIT ?? JUST THAT IF THEY WERNT READY AVAIL ?? THOUGHT ID GRAB ONE ..............WHAT DO I DO ??? DAVO
Tue Oct 01, 2013 9:19 pm
Buy the oz toff ebay one, that will fit your car.
Tue Oct 01, 2013 9:41 pm
that company also has points, caps, rotors for various Isuzu models
http://stores.ebay.com.au/Powerflow-Per ... =148246526
Tue Oct 01, 2013 10:26 pm
Has anyone fitted an Asahi R200 pump? They look totally different to a standard G150/G161 pump, so I'm hesitant to hit the 'buy now' button on Import Monster. Are they suitable?
Fri Apr 18, 2014 10:01 am
a link to the pump on the site would make it easier to give an opinion.
i looked for 15min before giving up!
Sat Apr 19, 2014 9:46 am
