doesn't look too flash there Gricey !
| Thu Nov 01, 2012 8:52 am |
gricey
No it does not . I have dewers performance engines on the job . Wally dewer is one of the best and a personal friend . Gricey
| Thu Nov 01, 2012 8:23 pm |
gricey
Found out why it gave up . The g200 has two cams and normal cam shaft drives the fuel pump and the oil pump . The oil drive on the cam was completely worn out .lucky I have a new one. Looks like I also have to sleeve two cylinders . . And I have sent the cams to get tricked up . Also I am looking fo 2 40mm webers if any one can help that would be good . Gricey
| Mon Nov 12, 2012 8:32 am |
oz_toffa
Gricey, i think you and Bellettboys need to get together and have a beer or 2 to wash down your dead motor woes.
she sure looks pretty sad.
what series is the twin cam with the alloy blue timing cover?
| Mon Nov 12, 2012 10:00 am |
gricey
No idear . Gricey
| Mon Nov 12, 2012 10:22 am |
gricey
Anybody give me a contact to get wheels widened. Gricey
| Sat Nov 17, 2012 10:03 pm |
There's a couple of places down here. On my phone right now but try Google wheel repairs. Craig probably knows some too.
| Sun Nov 18, 2012 4:36 am |
gricey
FIRST PHOTOS . THE FUN BEGINS . GRICEY
| Sun Nov 18, 2012 9:49 am |
gricey
Tried to send more photos no luck . Car was last registered 1982 . I got it off bob Blackwell when I bought the red gt . Notice crumple right front chassie . But all is prity good. Gricey
| Sun Nov 18, 2012 10:38 am |
looks pretty good, Gricey. Is it a complete car ?
| Sun Nov 18, 2012 9:42 pm |
gricey
I have most bits I think . Gricey
| Mon Nov 19, 2012 5:05 am |
gricey
Ok car is fully striped. Two items I will need to source are 1 disk brake rotor and torsion bar . Quite happ to pay . Gricey
| Tue Nov 20, 2012 9:09 am |
F3ARED
Quote: what series is the twin cam with the alloy blue timing cover? Gemini ZZ/R PF60E
| Thu Nov 22, 2012 1:34 am |
gricey
The body is ready to sand blast under in boot and engine bay . The only rust to repaiir is under front guards near the screen . Usual place . The g 200 has been re built just néed to get a head gasket . And timing chain tensions .and it's finished. Then the slow process of putting it all back together . The plan is taste 2014 . Doubt that I could make Adelaide .after restoring two cars I think this one will be spot on . Gricey
| Thu Nov 22, 2012 10:05 am |
gricey
up date .started to put back to geather . rear end almost done, g200 has been re bult. now the fun starts . gricey
| Wed Jan 23, 2013 6:38 am |
i can help with the rotor if you still need 1. timming chains ect i have put part numbers on here 1 needs a few links taken out. do you have twin cam timing chain set up they are a interferience engine and will bend valves if not correct.
| Wed Jan 23, 2013 6:53 am |
gricey
Greg . Yes I need a rota . Not sure about timing chain . The engineer has built the (g200 , gricey
| Wed Jan 23, 2013 8:21 am |
gricey
I am planing to fit 2 40m webers . To the g200" they do cost a fair bit I have been on the look for some time no luck.. About two weeks ago about 3 am I was sitting in the lounge thinking . Alfa fit webers . Recall taking a Alfa out of a shed . Non payer . And dumping it down the back . Went to look . Yep 2 40m . Beauty . Gricey
| Fri Feb 01, 2013 8:29 pm |
nice score from the alfa!
| Fri Feb 01, 2013 8:47 pm |
gricey wrote: I am planing to fit 2 40m webers . To the g200" they do cost a fair bit I have been on the look for some time no luck.. About two weeks ago about 3 am I was sitting in the lounge thinking . Alfa fit webers . Recall taking a Alfa out of a shed . Non payer . And dumping it down the back . Went to look . Yep 2 40m . Beauty . Gricey any more updates, Gricey ???
| Thu Aug 07, 2014 12:37 am |
