View unanswered posts | View active topics It is currently Mon May 04, 2026 2:58 am
Hub to rotor torque spec
Does anyone know the torque specification for attaching the front brake rotor to the hub?
My PR manual covers only drum brakes.
The JR manuals omit this spec (but go into great detail about how much grease is required for every bearing component down to the hundredth of a gram).
The PF manual says 5 kg-mm or 36 ft. lb.
Is the PF spec close to the PR spec?
Thu Dec 04, 2008 7:33 pm
I got a response from someone in Japan. The answer was 4.3-5.5 m-kg.
Sun Dec 21, 2008 12:35 am
Thanks for the update JT191. The more information we can accumulate here the better!
R.
Sun Dec 21, 2008 12:39 am
