PR95
Does anybody know where the reverse light switch is in a 1500 auto? I have checked from under and can't locate it, maybe it's in the shifter mechanism, just thought i would ask before going in to find it, as some of you have a workshop manuals. Thanks
| Sun Oct 02, 2011 10:20 am |
1500 auto.... what are u playing with now lads??!! i'll have a look 4 u.
| Sun Oct 02, 2011 11:07 am |
PR95
Whats wrong with 1500 auto's?
| Sun Oct 02, 2011 11:16 am |
WELL I GUESS HAVING A 1500 FOR A WHILE WOULD BE OK TILL THE TWIN CAM IS FITTED ...I HAD A LOOK IN MY BOOKS NO MENTION OF THE AUTOS THEN AGAIN I ONLY HAVE A LIMITED AMOUNT OF BOOKS CHEERS DAVO AND CLYDE WOULD BE PROUD OF WHAT YOU HAVE DONE
| Sun Oct 02, 2011 11:19 am |
PR95
Thanks Davo, don't think this one will ever get a twin cam, has got a 1600GT tho, will be regoed this week.
| Sun Oct 02, 2011 11:23 am |
had a look geoff.... no mention of the auto so it must have been an extra suppliment for the chassis manual. GT manuals were the same.
i do have a grainy photocopy of an auto sales brochure here, but it doesn't show enuf detail of things like that..... damn.
but the auto's are just a Borg Warner 35 unit, with the same adjustments as an XP Falcon (so I'm told), so maybe a search of a BW35 will show it from a different car? plenty of cars had them. alot of ford's, chryslers, leylands, etc. sounds silly, but they were all the same trans with different settings for each car, so it'd be worth a shot.
| Sun Oct 02, 2011 11:33 am |
what are we not playing with  . There are a few on the go some quick jobs and some long term gt's and wasps. Liz has a teardrop in the pipe line should be on the track early next year  .
| Sun Oct 02, 2011 11:36 am |
more!! bloody hell mate!! ur just gunna have to open a "Bellett Museum" before long.... little autos are ok. i wouldn't mind one for a laugh, and have always been rare, nowadays more-so with time and us not wanting them years ago.... be carefull putting lizzy on the track mate.... u'll regret it if she's quicker!!
| Sun Oct 02, 2011 11:43 am |
O.K., I have something to check out. I have an auto 'box out of a car, so I can have a look, but it's at Gary Carter's. I'll try & get a look tomorrow. Cheers, Matt.
| Sun Oct 02, 2011 12:19 pm |
oz_toffa
it appears that the start inhibit and reverse switch are on the same mechanism.
Manual says
Problem: Incorrect starter/Reverse lamp operation
Repair: Manual control linkage adjustment incorrect. Fix is adjust linkage Mounting screws loose. Fix is tighten screws Faulty connections or switch. Fix is repair connections or replace switch.
This doesnt really tell you where its located but it sounds like you could check park and neutral is working correctly as its the same mechanism.
| Sun Oct 02, 2011 12:26 pm |
PR95
Thanks guys, thought it would be a 2 minute job, climbed under car today and thought we would just be a matter of joining wires, but there are none, cant see where a switch woukld be, did find 2 wires going into harness with oil sender wire,but nothing from box, so will pull the shifter mechanism apart as I suspect will be in there somewhere.
| Sun Oct 02, 2011 12:29 pm |
oz_toffa
Reckon your right. Should not be a real hard job  Have fun!!
| Sun Oct 02, 2011 12:42 pm |
oz_toffa
Tourer...
dont remove the shift mechanism!!!
just looked at the spare trans in the shed.
the selector is coming in the trans on the right and the 4 connector switch is on the left as you look at the top of the trans with the bell housing to the front.
that is where the wiring should be going to. check further under the car.
can send a pic if you need it
| Sun Oct 02, 2011 1:09 pm |
PR95
Thanks OZ pick would be good if not to much trouble. Thanks Geoff.
| Sun Oct 02, 2011 1:45 pm |
oz_toffa
Here they are. Selector can be seen on right of the 1st pic. Switch is right near transmission cooler line connection.
| Mon Oct 03, 2011 7:30 am |
PR95
Thanks OZ
| Mon Oct 03, 2011 8:43 am |
PR95
Hey OZ, Checked out the car today and can't find switch,have had another look at the picture tonight and will have another look tomorrow, but have dicovered that I can start in gear,  so I wonder if switch has been removed. My question is, The first cable is the kick down cable, then the switch and then pipe, is that pipe to go to radiator for cooling?  if so my car has a manual radiator. Can see a manual gearbox looming here.
| Tue Oct 04, 2011 10:14 am |
opr-910
auto box in bellett doesn't have cooler in radiator. it has a vented bell housing. will check wiring in the daylight and report back later
| Tue Oct 04, 2011 10:58 am |
PR95
Thanks Lindsay, Just wondering what that hose is in the picture Oz posted
| Tue Oct 04, 2011 11:04 am |
opr-910
i would suggest it comes out of another car
| Tue Oct 04, 2011 11:08 am |
