View unanswered posts | View active topics It is currently Mon May 04, 2026 3:01 am
Reply to topic  [ 5 posts ]
Bellett Badges for Sale
I am now ready to release my small range of Bellett Badges to those in need. Although I am still experimenting in casting 1600GT badges in alloy, I have replicated the original diecast design and thickness with laminated plastic engraving plate on my Roland engraving machine (Now theres a Bellett just there) that I have used in conjunction with my Picture Framing business since 2007. My next one will be the long "Bellett" badge. Although I should be able to make the "1500" badge, I can't think of a way to create the thick chrome plated edges.They may have to have black edges. Check out the photos and prices below:
File comment: 1600GT double sided keyring, $10 satin finish or $13 glass finish
File comment: 45mm dia. hub centre cap badges, Glass finish $48 set of 4
File comment: Later model GT Front Grille badge $25 Glass finish with threaded mounting posts
File comment: Set of 3 1600GT Badges $50 per set flat satin finish or $65 per set raised glass finish.
Mon May 30, 2011 9:44 pm
I like the look of the key chain. Now I need to either find a flat headed screwdriver with a hole drilled in the handle, or find a lock cylinder with a working key in it, and I will be able to use a key chain.
The glass finish is the old style baked on clear finish?
Mon May 30, 2011 10:53 pm
WOW, they look fantastic!!
Tue May 31, 2011 12:42 am
They DO look fantastic!
Might have to raid the money box!
J.T., I take it you habe an ign lock cylinder? If so Dominion locks of Canada produced a key blank that is still available some places. You can take them to a locksmith & they skould be able to cut a key to match the lock. OR I could send you an old key & the smithy should be able to alter the tumblers to match the key.
Good luck.
Tue May 31, 2011 11:53 am
Hey Lewis,
Got the badges they look great, I have just returned form 2 weeks in NSW Country regions so I did not get them until today, Sunday.
Day off tomorrow, that will give me time to fit it up. :P
Thank you, I will fix the dollars this week when I get back to Sydney.
GREAT work, thank you. :o
DAVE m.
Sun Jun 05, 2011 6:46 am
