View unanswered posts | View active topics It is currently Sat Mar 21, 2026 10:40 am
Reply to topic  [ 8 posts ]
Front Indicator Lense 67 GT Bellett
I am chasing 1 white glass bee hive lense for the GT
Any clues of where to source
Regards
Sun Apr 24, 2011 11:25 pm
Looking for a couple myself - - this on EBay ( Item - 380193060716 ) caught my eye , might be a good option until correct lens turns up. Probably need a little modification but should not be expensive and is readily available.
Thu Apr 28, 2011 10:12 pm
Another option is the later style pr90 set up. You can't get them but i got a set of toyota one that are the same from japan.
If someone has a parts book i need a part number i will see if it can be got out of japan? btw if you need the hole assy they are left and right.
Thu Apr 28, 2011 10:29 pm
hi greg PART NUMBERS ARE
THE BEEHIVE LENS 8262-1253 THEN HAS (AP20-00002)
UNDER DESCRIPTION EXPLODED VIEW 8262-0197 FLASHER LAMP ASSY R.H. (AF101-8)
8262-0198 L.H. (AF101-7)
CHEERS DAVO
Fri Apr 29, 2011 12:04 am
i'll double check before anyone commits to buying them, but i think good ole morris minor indicator lense are exactly the same type.... but only if u can handle having the word "lucas" on a bellett. they are readily available.
let me verify this first tho, and i'll re-post.
Fri Apr 29, 2011 12:13 am
i will sit back until i know they want them before we chase them then thanks Brett.
Fri Apr 29, 2011 2:01 am
I thought that I needed 2 but I have just found them. Mini minor lenses look like they may be a good option for anyone wanting lenses.
Fri Apr 29, 2011 3:50 am
I had a spare with Lucas on it -- Almost the same slightly smaller diameter but you could make it fit if nothing else was available
Fri Apr 29, 2011 11:10 am
Users browsing this forum: Google [Bot] and 9 guests
