[ 5 posts ] |
Early GT
Hey Guys, Does anyone know where I can get 3mm steel or copper tubing (smaller than brake lines) to run as an original setup from the inlet manifold to the vacuum advance on the dizzie. I also need 1 male and 1 female 8mm thread compression fitting with olives to fit each end of the line. The new/old original VA I got from Dick Klinkhamer has a threaded fitting. See photos. Brake guys and Refrigeration guys ran a mile when I showed them these parts. I'll try Pirtek next to see if I could get the fittings at least and convert to rubber tubing.
Cheers, Lewis PS. My original starter motor rebuilt last week now works a charm!
| Sun Apr 24, 2011 12:08 am |
GerryBellettGT
Hi Lewis,good to here you got the starter sorted,my GT has rubber hose on vacuum,just been down to parts car,rubber hose,seem to recall seeing that tube on dizzy's in my dad's shed,will have a look for you next day or so,if find you can have Gerry
| Sun Apr 24, 2011 2:39 am |
Lewis do you want the hole copper pipe with ends? If so i will send you 1. bloody purists  .
| Mon Apr 25, 2011 12:31 am |
Early GT
Thanks Guys, The tube I have is too short and I will need fittings both ends. (Can't get the olive off the old one). I Already have the brass 8mm to 1/16 pipe thread fitting into the manifold though. I'm happy to buy a complete one from either of you.
Greg, Do you also have a spare air cleaner nut or 2 ?
| Mon Apr 25, 2011 8:21 am |
air cleaner nuts are no go i will be going to a stainless bolt shop next week to get some wing nuts. can you pm me your phone number as i had 2 trucks on the gold coast yesterday and 1 leaving in ten minutes for beenleigh if your quick  . i will try and get it to you.
| Mon Apr 25, 2011 8:54 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 10 guests |
