View unanswered posts | View active topics It is currently Tue Mar 24, 2026 12:09 pm
SEDAN REAR PARCEL SHELF SECTION WANTED
Hi All,
I am looking for somebody who has a sedan rear parcel shelf that is beyond use, but the speaker section is ok.
I just want the oval speaker slotted section and about 20mm or so around it.
Thu Jul 20, 2017 3:47 am
is that so you can make one speaker on each end parcel shelf sorry glenn I had one gave it to sticky years ago he may still have it ...cheers davo
Thu Jul 20, 2017 5:06 am
EXACTLY
Thu Jul 20, 2017 6:30 am
ok guys who is helping glenn out ??? I cant glenn sorry
Thu Jul 20, 2017 7:49 am
Glenn, I will check the rusty wrecks on the weekend. Working during daylight hours tomorrow. (For a change!)
Surely one will be ok!
:) Matt.
Thu Jul 20, 2017 10:36 am
:) Matt.
Thanks Matt, appreciate the help. I want to fit a modern radio semi-hidden, and the best place for speakers is in the back as i don't want to cut door panels etc.
Thu Jul 20, 2017 11:08 am
I've got one that I can cut out of a sedan that's half cut up already. will be out at my brothers this weekend so can grab it then.
PM me a postal address and I'll send you one down
Fri Jul 21, 2017 4:27 am
thanks sticky your the best .....
Fri Jul 21, 2017 4:28 am
Many thanks...... PM'd.
Fri Jul 21, 2017 10:48 am
Just to verify, is this the section you need??
Fri Jul 21, 2017 11:41 am
yes, plus the plastic section for the speaker..... ie the speaker 'grillee in the parcel shelf plus around 20-30mm around it
Fri Jul 21, 2017 10:56 pm
I'll check the spare parcel shelves I have but I think they all have perished grills from sun damage ??
Will double check and get back to you on that one.
Fri Jul 21, 2017 11:37 pm
sun damage is ok as i will repaint it anyway as i did with my parcel shelf.
Sat Jul 22, 2017 3:03 am
all good great to see the forum working again ...cheers guys
Sat Jul 22, 2017 5:36 am
Problem is they have become brittle and grill section has fallen apart.
I will be back out at my brothers tomorrow so will have a dig around in my container up the back paddock and see what I can find. There might be one intact buried in there somewhere.
Sat Jul 22, 2017 6:16 am
OK, thanks.
Sat Jul 22, 2017 11:18 am
If you don't have one sticky let me know, maybe able to help.
Geoff M
Sun Jul 23, 2017 11:22 am
I made a false panel out of MDF to go over the rear shelf. Covered it with carpet (thin) and mounted a speaker
cover onto it. Looks like a GT rear parcel shelf. The speaker cover I used was out of a Hyundai. Can't remember which model. If you don't do any good with Sticky's, I'll try and post a pic.
Mon Jul 24, 2017 1:29 pm
Thanks for the info. I did exact same thing many years ago on my 1st teardrop..... but for the Sport i want it to look as much original as possible, albeit with some modern touches not too visible.
Tue Jul 25, 2017 6:56 am
Sorry, had bit of a family emergency on Sunday to help with and never got out to the container.... but I will be out there tomorrow after work so will have a dig then.
Tue Jul 25, 2017 9:14 am
