View unanswered posts | View active topics It is currently Sun Mar 22, 2026 9:47 pm
Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
The one bellett part I really really want is a............
Not saying the rumour is correct.... Never confirmed myself, so hence, rumour.
Dean, number is 4110. Normal one is 4111.
Early version diff's are 379 for a 4.1 and 349 for 3.7. I want a 4110 tho.
I'll check my spare ones I have at my brothers place for you as soonn as I have a chance, may be a couple of weeks before I can get there though.
Thu Aug 25, 2016 9:57 am
Cheers.
No hurry.... Has a date with the welder before its used next year. ;)
Thu Aug 25, 2016 10:39 am
Numbers are stamped into the vertical rib under the fill plug.
Thu Aug 25, 2016 10:40 am
We have also got a couple of auto wrecks so will have a look Brett (after Nats Prob)
Thu Aug 25, 2016 11:28 pm
no rib or numbers here Brett.
Fri Aug 26, 2016 12:00 am
8-) You got them okay?
Fri Aug 26, 2016 1:23 am
Yep not a problem, Many thanks.
Got another auto as well so checking both at some point. Josh
14117884_10154369414638290_8766338451974864375_n.jpg [ 104.81 KiB | Viewed 26826 times ]
Fri Aug 26, 2016 3:36 am
Dean. Yesterday i dropped diff off to the guy for a check over. Will take 2 weeks. So i have two weeks to get this one out. I discovered that the x member can be removed from the diff without removing the yoke. You have to unbolt the diff of course then wiggle the x member at an angle and it comes off. I hope i can do that under the car to avoid removing several brake lines.
Fri Aug 26, 2016 6:50 am
Farmer heres health ??
Wed Aug 31, 2016 7:58 am
Coming a close second behind the elf is a bellett
Wed Aug 31, 2016 8:00 am
https://www.abouttimespares.com.au/show ... asp?cat=23
Some parts available
Wed Aug 31, 2016 11:33 am
Glenn wrote:
https://www.abouttimespares.com.au/showpartslist.asp?cat=23
I've bought a bit of gear off these guys over the years.
This is where I got Donkeys drivers door weather shield from..... they had 2 listed at the time (1 clear, 1 green tint) so I ordered both but they could only find the clear one in the warehouse (been on Donkey ever since)
Thu Sep 01, 2016 9:20 am
I got my reco'd diff back today. (Thanks Dean) It has the numbers on the casting as you suggested Brett. Slightly different sequence. You can see that the late model diff is totally different in the casting. The reco guy said he in his Bellett search, there are four different ratios listed. Obviously not in Oz though.
For the info of others, he got maybe the last of the carrier bearings available. The bearing is wider than any other that might fit. That would required spacers to be made etc. Driveshaft seals are not available.
Its weird, the differences. Change for change sake or are they improvements? The late diff has the drain on the rear. Obscured by the leaf spring so thats a backward step!
Thu Sep 08, 2016 9:44 am
the one bellett part i really really want is a Florian Wagon/van!
Sun Sep 11, 2016 10:55 am
