Teditor
_________________ Ted Freeman
| Tue Jan 26, 2016 2:53 am |
Teditor
| Tue Jan 26, 2016 2:55 am |
Teditor
| Tue Jan 26, 2016 2:57 am |
Teditor
...Using A Light Hammer & Chisel To Get The Boot Rubber Out...
| Tue Jan 26, 2016 3:07 am |
Teditor
| Wed Jan 27, 2016 11:31 am |
Teditor
| Wed Jan 27, 2016 11:33 am |
Teditor
| Wed Jan 27, 2016 11:35 am |
Teditor
.Some Rust Repair.
| Thu Feb 04, 2016 5:09 am |
Teditor
..Not The Best But I'm Getting There..
| Thu Feb 04, 2016 5:12 am |
Teditor
| Thu Feb 04, 2016 5:14 am |
Teditor
| Thu Feb 04, 2016 5:16 am |
Teditor
.....Replacement Of The Boot's Corner Was A Must, Still Not The Best Welds But I Will Keep Going Over Until Correct,So This Corner Still Needs Some Welding To Sort Out The Seam's, (Dad & I Picked Up A 2x4-Foot Sheet Of 1mm Cold-Roll Steel) More Then Enough To Do What We Want.....
| Thu Feb 04, 2016 5:26 am |
Teditor
......The Other Corner Has Far More Rust Damage In It......
| Thu Feb 04, 2016 5:29 am |
Teditor
| Thu Feb 04, 2016 5:32 am |
Teditor
........Grind Her Back A Bit........
| Thu Feb 04, 2016 5:35 am |
Teditor
| Thu Feb 04, 2016 5:36 am |
Teditor
| Thu Feb 04, 2016 5:39 am |
Teditor
...........Clean It All Up With A File...........
| Thu Feb 04, 2016 5:43 am |
Teditor
............I Carefully Pulled Back The Inner-Skin So To Tap-Out All The Rust Flakes & Crap Which Can Be Seen Through The Rust Holes, All Up There Was About 4 Heaped Table Spoons Worth Of Rust Flakes & Crap That I Was Able To Get Out............
| Thu Feb 04, 2016 5:48 am |
Teditor
| Thu Feb 04, 2016 5:50 am |
