View unanswered posts | View active topics It is currently Thu Jan 29, 2026 2:47 am
Reply to topic  [ 10 posts ]
cam shaft queries
Just wondering if there is any difference in the std cam shafts between the 3 bearing motor and the 5 bearing??
And is the cam in the 1500 the same as the GT 1600??
Sun May 31, 2015 11:14 am
Hi Sticky.
This is 1 of the mods Isuzu had done when they went from 3 brg. mains to 5 brg.
They changed the profile of the cam lobe to get better economy and from 6 brg. to 5.
Isuzu brought out a supplement to the engine manual explaining the difference.
The cams on all the engines are different. ie. 3 & 5 and cc rating. My parts books give me 4
different part numbers.
Sun May 31, 2015 1:03 pm
Hi Stickman,
Like the Crankshafts, the Cams are not interchangeable between early model 3 bearing and later 5 bearing engines.
Different number of Cam bearings between the 2 camshafts.
Later 5 bearing 1500 and 1600GT OK however
Sun May 31, 2015 10:01 pm
3 bearing GT and sedan had the same cam.
5 bearing GT had the same profile as the 3 bearing.
5 bearing sedan was a tamer profile for economy.
Mon Jun 01, 2015 8:09 am
Thanks guys
I have a NOS cam I bought a couple of years ago, now I just need to figure out what engine it's for......
I'll get the part number off the box and see if someone can isolate which one for me
Mon Jun 01, 2015 9:22 am
I have a 64/65 parts book and it has 2 numbers for cams 12511 224 (G150) & 12511 223 (G130)
Part number for my cam is 12511 333
Can anyone tell me which engine it's for? (please be GT please be GT please be GT :D )
Mon Jun 01, 2015 7:56 pm
Sorry to mention it is a 1300 and 1500 cam ( 1968 - 1975). The GT cam is numbered 12510-058. This cam has a little plug at the gearbox side in it ....
Gr Dick
Mon Jun 01, 2015 8:37 pm
Yep. 5 bearing sedan cam.
Least "GT" of the lot.
Tue Jun 02, 2015 2:17 am
Thanks Dick and Brett
Well I guess that rules it out for my GT engine then.......
Tue Jun 02, 2015 8:55 am
Tighe Cams for a re-grind
Tell him the Bellett nut from Tassie sent you
He's reground 3 for me so far.......
You won't look back
j
Tue Jun 02, 2015 8:58 am
Users browsing this forum: No registered users and 30 guests
