View unanswered posts | View active topics It is currently Fri Mar 20, 2026 10:28 am
g200w or g180w dipstick
Car(s): 1968 Bellett GT
hey guys im after a g200w or g180w dipstick if anyone has one spare. thanks
Wed Oct 02, 2019 5:10 am
Depends on what sump and dip stick tube you have.... there were 2 or 3 different ones.
Sun Oct 06, 2019 7:59 am
I have this type sump. Or does anyone know what other dipstick would fit this sump? One i could cut down to suit that will just fit the tube
Tue Oct 08, 2019 2:04 am
Waldo
That sumps looks similar to mine
I will have a look tomorrow night
i do not have a spare but i will take a photo, measure it etc
Cheers Flying
Wed Oct 09, 2019 1:57 am
Try a Gemini stick. I think the rubber sleeve is the same size and the length should be close. A tape measure will confirm or deny.
But make sure it's the same style Gemini sump.... because they had a couple of different ones as well.
Wed Oct 09, 2019 10:53 am
Waldo
The Dipstick is 300 mm long from the tip of the stick to the inside base. The high and low marks are 15 mm and 40 mm from the tip.
The blade looks about 5 mm wide and the stopper is about 8mm in diameter.
Hope this Helps
Flying
Thu Oct 10, 2019 11:39 pm
I think so too Brett. When I put a DOHC in one of my cars I used part (3/4) of a Gemini sump.
Mon Oct 14, 2019 3:26 am
