bellett.net
1967 Isuzu Bellett sedan small brochure - English language
http://ns1.bellett.net/forums/viewtopic.php?f=52&t=76
Author:  dave [ Fri Oct 03, 2008 8:59 pm ]
Post subject:  1967 Isuzu Bellett sedan small brochure - English language
This neat little brochure for the c1967 Bellett sedan is presented in a slightly-wider-than-postcard format and opens horizontally. There is also a bigger, full size version of the same brochure!
On the front cover we have the handsome Bellett cruising across the causeway....
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 01.jpg
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 01.jpg [ 88.29 KiB | Viewed 11966 times ]
...while the second page features two happy Japanese families parked with their Roman-red Bellett and white Bellett down by the water. Check out the scuba gear!
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 02.jpg
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 02.jpg [ 107.01 KiB | Viewed 11966 times ]
Onto the Engrish, with the proud announcement that the car has a 19.6 second quarter-mile time! I'd keep that one to myself normally.
Interesting to note the Bellett features 'living-room comfort', 'easy-to-scan' instruments and that all controls are positioned for easy accessibility to the driver. Then why are the wipers on the PASSENGER side of the car (on RHD at least)?!?!?!
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 03.jpg
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 03.jpg [ 111.19 KiB | Viewed 11962 times ]
Note the use of a nearly-midget-sized Japanese girl to show off the rear legroom. Belletts still using standard runners on the front seats have plenty of rear legroom as the front seats don't go back far enough! Check out the plastic on the door trims! Mint!
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 04.jpg
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 04.jpg [ 89.54 KiB | Viewed 11961 times ]
This panel is the one you see when you first open the brochure and features info on the engine. Pretty light on the Engrish on this page, but still good!
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 05.jpg
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 05.jpg [ 88.14 KiB | Viewed 11960 times ]
Finally we have the Bellett's specifications in metric and imperial measures like all good Bellett brochures. Plus a big area for your local dealer to put his stamp.
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 06.jpg
1967 Isuzu Bellett sedan brochure - English language - single sheet, 6-panels - panel 06.jpg [ 118.08 KiB | Viewed 11959 times ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
