| Twin Cam Conversion Bottom Radiator Hose http://ns1.bellett.net/forums/viewtopic.php?f=40&t=2494 |
Page 1 of 1 |
| Author: | flying [ Mon Sep 23, 2013 10:13 pm ] | ||
| Post subject: | Twin Cam Conversion Bottom Radiator Hose | ||
Hi Mad rush to get my baby on the road for the Nats Heres a pic so far Came up with one missing part -- the pipe between the oil filter and chain tensioner -- still chasing 8 mm banjo fittings What Bottom radiator hose fits this looking at the motor from the front Waterpump exit on right hand side goes down and under harmonic balacer then turns into bottom of bellet radiator -- Help Also can you strip the harmonic balancer back to the rear pulley as it wont let the fan turn Cheers Flying
| Author: | Glenn [ Tue Sep 24, 2013 3:27 am ] |
| Post subject: | Re: Twin Cam Conversion Bottom Radiator Hose |
looking good. try a place like Enzed or similar, the places that make hoses. They should have banjo fittings and the pipe also. Its too long ago when i did DOHC conversions, so can't help with hose numbers, apart from the usual, check out the stores stock, like Supercheap, Repco etc. do you have apicture of the balancer area ? glenn |
| Author: | flying [ Tue Sep 24, 2013 6:12 am ] |
Thanks Glenn I have been to all those places - Unfortunately this is the only 8 mm banjo on the car Everyone has 10 mm as the smallest-- Ordered the parts from England -- waiting game Cheers Flying |
| Author: | gt orphanage [ Tue Sep 24, 2013 7:35 am ] |
flying you need to put the harmonic balancer in a lathe and take it back to the back single pulley is the best solution or thermo fan is the other my cars have either solution. A vn commodore top hose will do the trick I cant help much more but I used 1 put it on the water pump try both ways to see it heads in the best position you will need to cut it in the middle as it will go away from the radiator I fitted 3 inches of exhaust pipe to join it with a few dobs of weld each end the hose from memory needed about 1 inch cut off from the radiator end. With a twin cam make sure you have a bleeder in the thermostat |
| Author: | oz_toffa [ Tue Sep 24, 2013 12:41 pm ] |
nice progress there, Flying. Keep it up. OZ |
| Author: | gt orphanage [ Tue Sep 24, 2013 8:36 pm ] |
will the banjo bolts from the gt carb overflow fit ? or of Gricey has some out of the engine he is building I can see if I can get some from a guy at home.Gricey will be over Friday. |
| Author: | Glenn [ Wed Sep 25, 2013 8:10 am ] | |||
| Post subject: | Re: Twin Cam Conversion Bottom Radiator Hose | |||
flying wrote: Thanks Glenn I have been to all those places - Unfortunately this is the only 8 mm banjo on the car Everyone has 10 mm as the smallest-- Ordered the parts from England -- waiting game Cheers Flying well, just had a thought, i had a Nissan 200SX back in '94 and the pipe on the turbo leaked water. They replaced it under warranty even though it was found to be something else..... anyway, i still have the pipe ! And, it's 7.8mm OD (near enough to 8mm) It has the banjo fitting s on the end. (2) They are 24mm OD and the hole is 14mm any good to you ? I can bring it over... Its like new. UPDATE: maybe you need the Banjo itself to be 8mm ? Thinking back, i think the pip you are refering too is fairly small?
| Author: | flying [ Tue Oct 29, 2013 9:34 am ] |
Hi Found the 8mm banjo at Enzed got some bundy tubing, solder and bobs your uncle Dragged it out of the shed today http://www.youtube.com/watch?v=waicH3u9hxE Fuel Line seems blocked don't want to pull the whole thing out taken the fuel cap off blown back into the tank with a compressor Now to connect up the senders and get everything going Cheers Flying |
| Author: | gt orphanage [ Tue Oct 29, 2013 10:51 am ] |
close now |
| Author: | oz_toffa [ Wed Oct 30, 2013 6:55 am ] |
Great progress there, George! should see you joining us on the next SA country afternoon cruise.... must feel exciting to have it moving on its own steam and not a push and a grunt to roll it about the shed OZ |
| Author: | BULLITT [ Wed Oct 30, 2013 7:08 am ] |
keep at it mate ...the roses you can smell ....don't look back look ahead and imagine your hands on the gt wheel driving down mum and dads old street ..yep the one where you used to live and your little project has waited long enough . for you to re u nite ...go George ,,,,well done mate cheers davo |
| Author: | flying [ Wed Oct 30, 2013 10:05 am ] |
Thanks Guys Yes it does feel good to have it moving Few gremlins to sort out Christmas cruise realistic target -- have to work this weekend Quick question -- Timing for the g180w is that 12 degrees? Cheers Flying |
| Author: | oz_toffa [ Thu Oct 31, 2013 12:42 pm ] |
dont know the details for Twin Cam, but 1500c. G150 motor is 14 degrees. reckon 10 would run it ok but there are those on forum with the full details i am sure does Google tell u? OZ |
