bellett.net
heater fan unit ?
http://ns1.bellett.net/forums/viewtopic.php?f=39&t=1512
Author:  jeffgair [ Tue Jun 21, 2011 3:58 pm ]
Post subject:  heater fan unit ?
hi folks,
Wondering about the heater fan in a '67 1500 4 door bellett deluxe. Does it have a fan at all or is it the through draft that pushes any interior heat in with no heat when car is stationary ?
thanks, jeff Scotland
Author:  PR95 [ Tue Jun 21, 2011 10:03 pm ]
Post subject:  Re: heater fan unit ?
Hi Jeff,
They have a fan heater that has a large oval rubber gasket that connects to underside of the fresh air box, and are switched from a second lever in the control box under the dash, that is activated with a push pull action.
Hope this helps.
Regards Geoff
Author:  Barney [ Tue Jun 21, 2011 10:03 pm ]
My 68 Deluxe has the same arrangement, wondering if it is original or not
Author:  pa_man [ Wed Jun 22, 2011 12:33 am ]
68 Deluxe should have a factory fan heater unit!
Author:  Barney [ Wed Jun 22, 2011 3:31 am ]
I suspected as much, amongst my parts was a second heater control panel, this one had the push pull fan control, I have put it in the car but have yet to find and install a fan
Author:  Pombellett [ Wed Jun 22, 2011 9:43 am ]
Jeff, I've got most of Rolie's innards in my shed. I wonder if GT Orph can remember what sort of heater he had, because you're welcome to it if it's any good.
Mark
Author:  gt orphanage [ Thu Jun 23, 2011 9:48 am ]
I think Rolie's set up was a core only without the fan style :?:
Author:  pa_man [ Sat Jun 25, 2011 2:07 am ]
Here are a couple of pics of the heater unit that sould be in a "68" :D
Author:  BULLITT [ Sat Jun 25, 2011 5:35 am ]
all boxed and ready to go to bonnie .. scotland ...joking regards davo
Author:  Farmer [ Sat Jun 25, 2011 11:40 am ]
Yep, that's how the fan boosted unit should look. For Aus delivered cars though, these are pretty uncommon. Story is that imported cars were required to have a percentage of Australian content. 'Standard' cars had no heater, but many were fitted with a non-boosted unit as a dealer fit (along with radios, carpets & DeLuxe badges) to bring this content up. They called this "DeLuxe equipment". This changed in 1968 as the boffins changed the rules to allow full imports. Then you could buy a 'Standard' or a proper DeLuxe with the stainless window frames, etc.
For '67 & earlier, to get a boosted heater you had to find a fully imported DeLuxe. Some were brought in , and 'Doris' is one of them. She is my '66 teardrop auto DeLuxe.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
