bellett.net
removing bellett front guards
http://ns1.bellett.net/forums/viewtopic.php?f=38&t=3121
Author:  sdoubleb [ Mon Aug 31, 2015 11:17 am ]
Post subject:  removing bellett front guards
Ok trying to remove the front guards off the new rust bucket pretty sure I've got all the bolts, did they use sealer an glue these frigging things on at the factory cause these will not budge ?
Author:  rod [ Mon Aug 31, 2015 11:24 am ]
Post subject:  Re: removing bellett front guards
you need to take doors off first ....as there are bolts you need to get out cant get these out with door on ....
Author:  sdoubleb [ Mon Aug 31, 2015 11:49 am ]
Yeah doors don't wanna come off either haha need a impact driver but I did get the 4 bolts out without removing door
Author:  CQGT [ Mon Aug 31, 2015 12:48 pm ]
There are 5 bolts. 6mm with 10mm hex. 1 is tucked up under the guard near the bottom of the "A" pillar. The other 4 are in front of the door. There is also a 8mm bolt and nut, 12mm hex, on the bottom. In the assembly they used a sealant that can be broken by using a thin bladed tool such as a putty knife. Your on a big learning curve. I still am. Don't be afraid to ask questions.
Author:  Stickman [ Tue Sep 01, 2015 3:47 am ]
Impact driver is always a handy bit of kit but sometimes even it needs the helping hand of the screws being preheated with an oxy first (get em red hot them let them cool, breaks the rust. Then give em a whack with the impact driver)
Author:  sdoubleb [ Tue Sep 01, 2015 5:03 am ]
Hmm might have missed the 1 by a" pillar. Got a impact driver today and a 4ltr wd40 today :evil: so will let it have it tonight.
Author:  sdoubleb [ Fri Sep 04, 2015 9:28 am ]
Had a win... Did have all the bolts out. Sealant holding front guards on looked like sikaflex had the hit a sharp knife around joins using a mallet :? . Got door off with persuading it with blow torch and impact driver. On to the other side now
Author:  flying [ Fri Sep 04, 2015 10:01 am ]
Looks tidier than most
Keep up the good work
Flying
Author:  yellowperil [ Sun Sep 06, 2015 7:21 am ]
Well done. Sometimes it can be a pain getting stuff off. Bolts and nuts are often not obvious but then you had to solve the sealant problem. It's good to see you wanting to do a strip down as you find so much stuff that will only cause problems later. Good luck with it. It all looks good from your pics.
YP
Page 1 of 1 All times are UTC
http://www.phpbb.com/
