bellett.net
Interior Door Trim and Rear Quarter Panel Clips
http://ns1.bellett.net/forums/viewtopic.php?f=37&t=3726
Author:  peterd [ Thu May 06, 2021 12:52 pm ]
Post subject:  Interior Door Trim and Rear Quarter Panel Clips
Does anybody out there have any of these clips they wish to sell or point me in the direction to obtain some?
The secure the stainless strip on the inner door cards and rear quarter. I believe they are unique to the GT but could be wrong.
Author:  KJB [ Fri May 07, 2021 1:29 am ]
Post subject:  Re: Interior Door Trim and Rear Quarter Panel Clips
Try..... Wirth...... they market a really wide range of good quality clips etc.. May even have a plastic equivalent.
Also - Motor Trade Suppliers.....Vic.
Author:  Glenn [ Fri May 07, 2021 4:57 am ]
Similar are fitted to my Sport holding the door pockets. I had some tin plate that i just cut up and bent to suit. Worked fine. Maybe even a tin can. Probably will last as long as the originals.
Author:  Glenn [ Fri May 07, 2021 5:00 am ]
http://www.motortradesuppliers.com.au/mts/default.aspx
Author:  CQGT [ Fri May 07, 2021 10:38 am ]
Hi Peter.
Try a craft shop. A shop that has paper, ribbon, matchsticks, paddle pop sticks and all sorts of fasteners.
We have Sollys. Dollars and Sense. Less than $5.00 stores. In Qld.
They may have a round head on them but all it needs is have it fit the slot.
Author:  flying [ Mon May 10, 2021 3:13 am ]
Hi
Try Paper Binders from a stationary store
Author:  CQGT [ Mon May 10, 2021 1:29 pm ]
Flying.
Yes. I reckon would do the trick. Bend the tops to fit the slot. The washers would assist with the pressure
to hold onto the backing panel.
Author:  peterd [ Tue May 11, 2021 5:08 am ]
Thanks Guys for all your help with this. Paper binders are the way to go and I have found the perfect fit with a little trimming.
Thanks again
Regards
Page 1 of 1 All times are UTC
http://www.phpbb.com/
