| cam shaft queries http://ns1.bellett.net/forums/viewtopic.php?f=36&t=3055 |
Page 1 of 1 |
| Author: | Stickman [ Sun May 31, 2015 11:14 am ] |
| Post subject: | cam shaft queries |
Just wondering if there is any difference in the std cam shafts between the 3 bearing motor and the 5 bearing?? And is the cam in the 1500 the same as the GT 1600?? |
| Author: | CQGT [ Sun May 31, 2015 1:03 pm ] |
| Post subject: | Re: cam shaft queries |
Hi Sticky. This is 1 of the mods Isuzu had done when they went from 3 brg. mains to 5 brg. They changed the profile of the cam lobe to get better economy and from 6 brg. to 5. Isuzu brought out a supplement to the engine manual explaining the difference. The cams on all the engines are different. ie. 3 & 5 and cc rating. My parts books give me 4 different part numbers. Dave. |
| Author: | Asroc66 [ Sun May 31, 2015 10:01 pm ] |
Hi Stickman, Like the Crankshafts, the Cams are not interchangeable between early model 3 bearing and later 5 bearing engines. Different number of Cam bearings between the 2 camshafts. Later 5 bearing 1500 and 1600GT OK however Cheers J |
| Author: | PR91 [ Mon Jun 01, 2015 8:09 am ] |
3 bearing GT and sedan had the same cam. 5 bearing GT had the same profile as the 3 bearing. 5 bearing sedan was a tamer profile for economy. |
| Author: | Stickman [ Mon Jun 01, 2015 9:22 am ] |
Thanks guys I have a NOS cam I bought a couple of years ago, now I just need to figure out what engine it's for...... I'll get the part number off the box and see if someone can isolate which one for me |
| Author: | Stickman [ Mon Jun 01, 2015 7:56 pm ] |
I have a 64/65 parts book and it has 2 numbers for cams 12511 224 (G150) & 12511 223 (G130) Part number for my cam is 12511 333 Can anyone tell me which engine it's for? (please be GT please be GT please be GT |
| Author: | Dick [ Mon Jun 01, 2015 8:37 pm ] |
Sorry to mention it is a 1300 and 1500 cam ( 1968 - 1975). The GT cam is numbered 12510-058. This cam has a little plug at the gearbox side in it .... Gr Dick |
| Author: | PR91 [ Tue Jun 02, 2015 2:17 am ] |
Yep. 5 bearing sedan cam. Least "GT" of the lot. |
| Author: | Stickman [ Tue Jun 02, 2015 8:55 am ] |
Thanks Dick and Brett Well I guess that rules it out for my GT engine then....... |
| Author: | Asroc66 [ Tue Jun 02, 2015 8:58 am ] |
Tighe Cams for a re-grind Tell him the Bellett nut from Tassie sent you He's reground 3 for me so far....... You won't look back Cheers j |
