View unanswered posts | View active topics It is currently Thu Apr 09, 2026 10:08 pm
How many $
Any one give me a idear how mutch I should pay for a Gemini engine weber carb complete dohc.. With. A 5 speed box . Or just the box on its own. This engine was a good runner . Gricey
Sat Mar 29, 2014 12:35 am
is it a twin cam gricey :?: twin weber or single :?: sorry your post is not clear.
Sat Mar 29, 2014 12:39 am
Sorry Greg . It's single cam and single carby . I am realy only interested in the box . Gricey
Sat Mar 29, 2014 12:42 am
Same engine as my Gemini . And Brett's race car . Gricey
Sat Mar 29, 2014 12:44 am
ok the dohc threw me. The 5 speed will not bolt to your twin cam :( if that is your plan. Or do you want it for your Gemini.
Sat Mar 29, 2014 12:46 am
[thaught it might bolt up to the twin cam . Gricey
Sat Mar 29, 2014 1:43 am
think you would need a rodeo box or maybe Gemini diesel one?
and different tailshaft to suit the box as well
Sat Mar 29, 2014 4:33 am
i can get a 1600 gemini engine down here from around 200 for complete runners, and that is complete carby to sump to alternator, just no gearbox. hope that helps?
Sat Mar 29, 2014 8:24 am
I have a rodeo box in my Gemini its single cam . If a rodeo box is needed for the twin cam . Why doesn't the 5 speed that's with the single cam that's for sale fit the twin cam . Gricey.
Sat Mar 29, 2014 7:46 pm
Rodeo with the c series diesel has the starter on the left, same as bellett & dohc isuzu. Diesel gemini has the starter on the right same as petrol gemini.
Sat Mar 29, 2014 11:15 pm
I think you can swap a Rodeo box housing with a Gemini one to get a 5 speed for a DOHC.
Sat Mar 29, 2014 11:23 pm
Yep but only the c series diesel one.
Sun Mar 30, 2014 11:06 am
Gricey
I'm still confused......
o you want a Gemini engine with 5 speed
or a DOHC with 5 speed
or a Gemini 5 speed box only
or a DOHC 5 speed box only ??
Sun Mar 30, 2014 9:53 pm
think Gricey wants a 5 speed that will bolt up to his Twin Cam???
claws here in SA has a Twin Cam in his '65 sedan and it has a Rodeo 5 speed mated to it.
thanks for the clarification, Redzone.
i knew it was Rodeo related but good to know what its a C series and that its diesel
Sun Mar 30, 2014 10:03 pm
In a nut shell Gricey, you need a box with the starter motor on the passenger side. :D
Sun Mar 30, 2014 10:22 pm
You could cut the bell housing from a bellett and shut it to a 5 speed. Or the 5 sp you bought up for me has had the starter hole put in. The mickey mouse box as it has 2 mickey mouse ears. :roll:
Sun Mar 30, 2014 11:42 pm
you can also cut and shut the gemini box to move the starter if you are a pretty good alloy welder, or know somebody
Mon Mar 31, 2014 12:02 am
That's what is was trying to say down the middle of the bell housing with a couple of cross ribs or strength and prevent cracking.
Mon Mar 31, 2014 12:07 am
you would have to remove the guts of the box and welder would need to pre-heat the whole shebang then weld it.
Mon Mar 31, 2014 2:29 am
Redzone, what year did the C series diesel hit our shores?
having some trouble pinning it down.
cheers
Mon Mar 31, 2014 10:27 am
