View unanswered posts | View active topics It is currently Fri Apr 10, 2026 4:05 am
Reply to topic  [ 16 posts ]
MOTOR WANTED
HI GUYS HAD AN EMAIL FROM JAMES IN TASSIE HE HAS THE SEDAN WITH THE EARLY GRILLE AND TAILLIGHTS HAS THE LATER BODY OR WHATEVER .....HE DEPERATELY WANTS A G161 BLOCK WITH 5 BEARING BOTTOM END HAS CASH WAITING ANYONE GOT A SPARE ONE ?? HIS PHONE NUMBER 61403992195 CHEERS DAVO
Thu Jan 23, 2014 1:59 am
hi guys any luck with a g161 motor ?? he is on the forum he bought stickmans sister car from w.a the orange one james is a great bloke needs a hand loves the belletts ...anyone hot a motor that needs work pm me cheers davo
Tue Jan 28, 2014 8:22 am
G161 blocks about as rare as rocking horse do do, Davo. :oops:
Tue Jan 28, 2014 10:17 am
thanks Geoff I wasn't aware of that ...im learning everyday maybe I should sell him my car it has a flo motor.....cheers davo
Tue Jan 28, 2014 11:08 am
Not sure how accurate this is, but i heard that G150 blocks can be bored to 1600cc.
Tue Jan 28, 2014 9:49 pm
that may work, but for the purist at heart it still says G150 on the block.
depends how anal you want to be regarding originality!
some do, some dont, some sit on the fence and cheer
and yes the last one i got was from a Florian. i could borrow the 1973 Chev Luv engine if it came to it. if i needed to
good luck with the search
Wed Jan 29, 2014 7:25 am
Gemini rods and pistons will fit after being bored. Warning check deck heights as every engine we have done has different deck heights. In 1 case we took 30 thou off. So clearances need to be checked.
Chev luv will be a good donor engine and a light conversation with opr91 a couple of weeks ago to reference on rebuilding engines we had a deep and meaning full on the luv engines. The g161 comes in three variants early and late in the push rod style before the Gemini engine.
Both stamped g161 and look the same on the outside but inside the provision for a 5 bearing block exists the rear main seals is a round rubber seal instead of a wick. Timing chain tensioner is hydraulic. But the timing cover will look a little different only a real purist will pick up on it 8-)
I believe a S.A member wrecks a few luv's :?:
Also cam bearings are a little hard to find :roll:
Wed Jan 29, 2014 9:42 am
correct we have wrecked a few. but all were gemini series engines.
only early one i have seen in last 5 years or so was the Vic wreck one and it may or may not have sold and the NSW country which your truly bough home for myself. and its way too good to wreck!
will keep asking and keep looking. our oz luv trucker dumped a few of the early ones before he realized Bellett guys wanted them.
:o :o :o :o :o :o :o :o :o
Wed Jan 29, 2014 12:43 pm
what about a DOHC engine instead ?
Wed Jan 29, 2014 11:57 pm
Yes Please. :roll:
Thu Jan 30, 2014 3:40 am
G161.... good luck.
I've got a couple. 1 is allocated to a car, 1 is spare, but I'm not parting with either.
a G150 will go to 1622cc if done right.
Sat Feb 01, 2014 12:21 am
Yes Please. :roll:
a reality check here, means that the G200 DOHC engine I bought in from Japan, will need to find a new home. It also has a 5 speed but I will most likely keep that for the Sport.
Sat Feb 01, 2014 5:35 am
Can G161 SOHC be changed to standard G161 ?
Sun Feb 23, 2014 2:19 am
You would need to check if head bolts line up and there is room for the push rods? Assuming the OHV cam shaft would fit?
This is part of an 1800 SOHC head gasket you could compare with the OHV gasket.
Sun Feb 23, 2014 3:45 am
luv engine for sale in Victoria on ebay under luv.
Fri Mar 28, 2014 11:08 pm
thanks. i am giving it a go as we speak....
cheers
Sat Mar 29, 2014 4:34 am
