| Hub to rotor torque spec http://ns1.bellett.net/forums/viewtopic.php?f=35&t=206 |
Page 1 of 1 |
| Author: | JT191 [ Thu Dec 04, 2008 7:33 pm ] |
| Post subject: | Hub to rotor torque spec |
Does anyone know the torque specification for attaching the front brake rotor to the hub? My PR manual covers only drum brakes. The JR manuals omit this spec (but go into great detail about how much grease is required for every bearing component down to the hundredth of a gram). The PF manual says 5 kg-mm or 36 ft. lb. Is the PF spec close to the PR spec? |
| Author: | JT191 [ Sun Dec 21, 2008 12:35 am ] |
| Post subject: | Re: Hub to rotor torque spec |
I got a response from someone in Japan. The answer was 4.3-5.5 m-kg. |
| Author: | 2ldohc [ Sun Dec 21, 2008 12:39 am ] |
Thanks for the update JT191. The more information we can accumulate here the better! Cheers, R. |
