| rear wheel cylinder problem. Help ! http://ns1.bellett.net/forums/viewtopic.php?f=35&t=1875 |
Page 1 of 2 |
| Author: | jeffgair [ Tue Apr 24, 2012 9:48 am ] |
| Post subject: | rear wheel cylinder problem. Help ! |
Hi folks, jeff in Scotland here. Got weeping seals in my rear wheel cylinders. Bores look good, seals look knakkered. Anybody know a replacement seal off the shelf from another manufacturer. Want to try to avoid resleeving for the time being. Many thanks, jeff |
| Author: | gt orphanage [ Tue Apr 24, 2012 10:46 am ] |
| Post subject: | Re: rear wheel cylinder problem. Help ! |
Jeff send Dick a p.m would be your 1st port of call. there is a repco part number in the parts section on the forum i can see if they are still around or i get a company to do mine they get them from somewhere Greg |
| Author: | oz_toffa [ Tue Apr 24, 2012 12:43 pm ] | ||
| Post subject: | Re: rear wheel cylinder problem. Help ! | ||
Front seal P6121 Rear seal P5151 Cyclinder Kit Master K7308X below is pic of rear seal Attachment: IMG-20120424-00007.jpg [ 113.09 KiB | Viewed 35631 times ]
| Author: | BULLITT [ Tue Apr 24, 2012 12:57 pm ] |
hi there oz toffa what do they cost for the seals ? mines arnt leaking but good to have spares ?ready avail? ...still waiting for the nz blinker stork ...waiting waiting ...it will come cheers davo |
| Author: | oz_toffa [ Tue Apr 24, 2012 1:02 pm ] |
less than $10 dollars each. older receipts say $5.15 but from memory last few i bought were still reasonable.. and still easily available. most PBR seem to have stock on shelves not so sure of O/S though could always drop a few in the post, Jeff. OZ |
| Author: | 65bellett [ Wed Apr 25, 2012 12:19 am ] |
Hi Jeff I think but I can't be 100% that you can use Morris Oxford seals or you may be able to use the entire wheel cylinder. As you are in the U.K these might be some thing you can get your hands on. |
| Author: | jeffgair [ Wed Apr 25, 2012 8:30 am ] |
many thanks for all your help guys. Will Dick in Holland a go, or try the morris oxford route ! Thanks, Jeff |
| Author: | 65bellett [ Wed Apr 25, 2012 8:37 am ] |
I have just spoken to tomanybelletts (craig) and he uses Morris 1000 rear wheel cylinders on one of his cars. You have to change the nut as the bellett brake nut won't fit. If you do go down the path of using another part I would love to know the part numbers and costing as I might grab a couple for spares |
| Author: | jeffgair [ Wed Apr 25, 2012 10:07 am ] |
mr 65 bellet, So delighted to have this site with fellow bellet owners, as these cars ain't falling out of the trees here in Scotland. Theres only 1. mine. Have tried to use MG magnette rear wheel cylinders which look pretty much identical to the morris 1000 ones as recommended by dick in Holland. Could not get rid of the air from the system as these cylinders don't have any bleed nipples. Be interested to hear how craig overcame this. Also googled pbr trying to find part number p5151 but nothing seems to come up - dont understand why as i can see p5151 printed on the packet of the photo that oz toffa posted. Any suggestions? Thanks guys |
| Author: | oz_toffa [ Wed Apr 25, 2012 11:26 am ] |
Jeff PBR do a local numbering system here in AU so unless someone else is selling NOS or stock online, it probably wont show up. I was quite serious about putting a few sets of front and real seals into postage and send over. and also Master cyclinder kit if you want it. just let me know. direct work email is chris.browning@oce.com OZ |
| Author: | BULLITT [ Wed Apr 25, 2012 1:01 pm ] |
good gesture oz toffa ...keep em all up and going cheers davo |
| Author: | 65bellett [ Wed Apr 25, 2012 1:19 pm ] |
If you already have the wheel cylinders and they fit you are half way there. If you use this part http://www.ebay.com.au/itm/Rear-Brake-B ... 4158wt_812 you should be able to bleed them up and get out there Belletting. |
| Author: | jeffgair [ Wed Apr 25, 2012 9:19 pm ] |
Mr Oz toffa, think I'l take you up on your offer ! Think its better to keep parts as original as possible so I'm gonna run with re sealing old cylinders and keep the brake bleedy thing in reserve, but thank you for the info 65 bellett - if either of you guys (or anyone on the forum needs stuff sourced in Britain give me a shout). Thanks all, Jeff |
| Author: | BULLITT [ Wed Apr 25, 2012 9:44 pm ] |
hey jeff what bout a shot of your ''wee beastie'' we all love to see where each other are up to on their cars ..good luck with the brakes we need em especially in reverse .... cheers davo |
| Author: | oz_toffa [ Wed Apr 25, 2012 11:57 pm ] |
2nd that. love seeing photos of Belletts update on part numbers. PBR have changed some things. P6121 Front Seal $5.00 each P8348 Rear Seal $4.20 each cheaper than when i last bought some?? on shelves and seems like plenty of stock. one set on the way to Jeff as soon as i have his address. Probably send in a CD case. OZ |
| Author: | Glenn [ Thu Apr 26, 2012 2:15 am ] |
where did you buy the parts from? My local Repco branch has no record of these numbers. glenn |
| Author: | oz_toffa [ Thu Apr 26, 2012 4:25 am ] |
local Power Brakes branch in SA website is powerbrakes.com.au not sure if SA only or interstate OZ |
| Author: | Glenn [ Thu Apr 26, 2012 5:43 am ] |
appears to be SA only tried my local Bursons and no stock glenn |
| Author: | 65bellett [ Thu Apr 26, 2012 7:38 am ] |
Glenn I have no doubt BGT would have them or would have no problems getting hold of them and they are over your side of town now. |
| Author: | Glenn [ Thu Apr 26, 2012 7:40 am ] |
I don't need them as no car but thought if they were available locally might stock up anyway I found some but a bit of a drive away didn't think of BGT though. I have dealt with them many times in the past. They did the clutch in my old GT too.. * BGT have been in Dandenong for as long as I can remember. glenn |
| Page 1 of 2 | All times are UTC |
