| interchangable head http://ns1.bellett.net/forums/viewtopic.php?f=34&t=870 |
Page 1 of 1 |
| Author: | gt orphanage [ Thu Apr 15, 2010 8:29 am ] |
| Post subject: | interchangable head |
Can anybody comfirm if a head off a 5 bearing engine will fit a 3 bearing block? |
| Author: | PR20 Auto [ Fri Apr 16, 2010 12:17 am ] |
| Post subject: | Re: interchangable head |
I do know that a three bearing head will fit a five bearing block if you drill out the bolt holes (from 10mm to 12mm). I can't see why the opposite can't be true if you re-tap the block (from 10mm to 12mm). (Some-one on this forum owns the auto sedan that has a three bearing head on it. I helped to do it. It also has one of my rear windows with it to replace the broken one it had on it when they bought it.) |
| Author: | PR20 Auto [ Fri Apr 16, 2010 12:21 am ] |
I just thought. You could also sleeve the bolt holes, but that would leave you with the skinny little 10mm three bearing head bolts. |
| Author: | gt orphanage [ Sat Apr 17, 2010 2:46 am ] |
thank you that helps me make the decesion at hand. |
