View unanswered posts | View active topics It is currently Mon May 04, 2026 12:30 am
interchangable head
Can anybody comfirm if a head off a 5 bearing engine will fit a 3 bearing block?
Thu Apr 15, 2010 8:29 am
I do know that a three bearing head will fit a five bearing block if you drill out the bolt holes (from 10mm to 12mm). I can't see why the opposite can't be true if you re-tap the block (from 10mm to 12mm).
(Some-one on this forum owns the auto sedan that has a three bearing head on it. I helped to do it. It also has one of my rear windows with it to replace the broken one it had on it when they bought it.)
PR20 Auto
Fri Apr 16, 2010 12:17 am
I just thought. You could also sleeve the bolt holes, but that would leave you with the skinny little 10mm three bearing head bolts.
PR20 Auto
Fri Apr 16, 2010 12:21 am
thank you that helps me make the decesion at hand.
Sat Apr 17, 2010 2:46 am
