Mini Review TL866 Programmer
EPROM EEPROM SRAM NVRAM Flash chips, reading/writing hardware and software
jca
cars: HQ monaro
vz ss thunder
ve ss sports wagon
Re: Mini Review TL866 Programmer
Post by jca »
I'm using the USB Mini pro
jca
cars: HQ monaro
vz ss thunder
ve ss sports wagon
Post by jca »
'quipt4it
cars: VS SS Commodore
VZ SV6 (daily)
Post by 'quipt4it »
Did you erase the chip first (UV) and blank check.
Also pin contact is sometimes an issue. Swipe chip from side to side while holding the 'lever' down slightly so it exerts pressure against the pins.
jca
cars: HQ monaro
vz ss thunder
ve ss sports wagon
Post by jca »
Ya erased and says it blank
antus
Site Admin
cars: TX Gemini 2L Twincam
TX Gemini SR20 18psi
Datsun 1200 Ute
Subaru Blitzen '06 EZ30 4th gen, 3.0R Spec B
Nissan s13 Silvia for track. SR20, E85, 18psi
Post by antus »
This is sometimes caused by the programmer not being able to get enough power. Try a different USB cable if you can. Some super cheap ones cant provide enough power to put the chip in programming mode. Verify=FF shows the erase part is probably good and correct.
Have you read the FAQ? For lots of information and links to significant threads see here: http://pcmhacking.net/forums/viewtopic.php?f=7&t=1396
